HID + Halo Projectors
Old Sep 10, 2004
Satanic-Hamster's Avatar
Satanic-Hamster is an unknown quantity at this point
There are tons of Retrofitting the HID kits into the TYC projectors. I personally like the halo projectors better, but is it harder to retrofit HID's into these projector headlights?
P.S. I'm a noob when it comes to custom fit stuff, but why is retrofitting so hard? And why doesn't H1 bulbs fit into the projector headlights?
Old Sep 10, 2004
ImPulse's Avatar
I believe halo projectors use different bulb #s... Check out the headlight lense (It should mention the bulb size). Retrofit = Retrofit, It can be done.
Old Sep 10, 2004
JayFReaZy's Avatar
Well, u have to find the actual projector that will fit inside the halo's. I've taken my halo's apart and removed the actual "projector", and could replace it with another one. However, it'd have to be the same size, and thats where the hard part comes in to play, cuz u dont know which projectors will fit in there. What do u mean "why doesnt H1 bulbs fit into the projector headlights? Are you asking why dont HID bulbs fit in stock halo projectors, or why do retrofitted projectors dont fit regular H1 halogen bulbs?
Old Sep 10, 2004
D-Vus CIV's Avatar
my civic gets me pu**y.does yours???
D-Vus CIV can only hope to improve
Mine fit h1 bulbs.but I have sonars.
Old Sep 11, 2004
I meant H1 HID bulbs fitting inside the projector
Old Sep 11, 2004
ImPulse's Avatar
The opening needs to be enlarged... You would need to use a file.
Old Sep 11, 2004
Is that really difficult?
Old Sep 12, 2004
ImPulse's Avatar
No, RiceBoy did it,
PM me if you have any questions...
ID:	37788   Click image for larger version
ID:	37789   Click image for larger version
Old Sep 12, 2004
Originally Posted by ImPulse
No, RiceBoy did it,
the file pissed me off because it took way too long to file out as much as you need to in order for the bulb to clear, so i used a drill..
Old Sep 13, 2004
wow, so those pics are the h1 HID kit on Halo projectors?
Old Sep 13, 2004
ImPulse's Avatar
H1 kit in TYCs
Old Sep 13, 2004
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
yup, and you can see why you should NOT put HID's into projectors that were not made for HID.
The beam pattern is horrible and has discoloration in the pattern too.
That one on the wall is soooooooo bad.
Old Sep 13, 2004
ImPulse's Avatar
compared to this,
http://www.intellexual.net/hids/ece.jpg
Yes... Its not great
compared to this,
http://www.intellexual.net/hids/5.jpg
Its amazing...
I' am still surprised that the TYCs even have a cutoff
Old Sep 13, 2004
Hefe's Avatar
X
All i see
Old Sep 13, 2004
JayFReaZy's Avatar
I dont see why its so bad. I bet u it lights up the road better than halogen in OEM housing, or halogens inside a projector. Yes, its not as good as a retrofit, but not everyone has $500-$800 to spend on just lighting. For 280$ i think its worth it. Pics are nice, and u can see the improvement. Its not like this was for nothing. Nice pics riceboy.
Old Sep 13, 2004
gh0st's Avatar
TAQUITOS!!!!
here you go
ID:	37952   Click image for larger version
Old Sep 13, 2004
ImPulse's Avatar
X
All i see
click the links..
Old Sep 14, 2004
Hefe's Avatar
Impulse....
Compared to the actual HID projector, yes id doesn't compare.
But against that ugly H4 Civic Hatch with the fluted lenses with massive glare, yes it is somewhat better. Just cause the TYC's do have a decent cut-off, (except the "bubbles" coming up on the sides)
But the overall pattern is still ugly and discolored, yes it is "brighter than stock or stock projectors"
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
