Please Help!!! Tyc Headlights Fogged!!!
Old Aug 31, 2004
civic02ex's Avatar
got banned
civic02ex is an unknown quantity at this point
Exclamation Please Help!!! Tyc Headlights Fogged!!!
Hey guys,
It just finished raining a while ago and guess what? My 02 Civic's black TYC Projector Headlights are fogged! (check out the pics) I thought these were like factory sealed headlights. I've had these projectors on since July and it's rained a few times since then and NO problems until NOW!! HELP!!! What can I do to fix this? I would greatly appreciate all your suggestions!
Thanks in advance!
Old Aug 31, 2004
civic01vtec's Avatar
posting in the right forum > you
seal them up with some silicone
Old Aug 31, 2004
civic02ex's Avatar
got banned
I did that on my tails, but not on the TYC because I fully inspected them and they looked pretty darn sealed. Plus, I have always heard that you did not need to do that (unless they are generic). . . I mean these are TYCs. Anyways, it's a little late for sealing with silicone because they're already fogged. I'm looking for a solution for the fogging. Anything I can do about that? I hope I don't have to go through the hell of returning them and all (since they are supposed to have a warranty).
Old Aug 31, 2004
FaiJai's Avatar
FaiJai is an unknown quantity at this point
guy, in what i know any aftermarket headlights should be re-sealed even though you they are factory sealed. IMO use your stock lights for now until the TYC arent fogged up and re-seal them even though you don't want to. that's the only solution.
Old Aug 31, 2004
all aftermarket lights should be sealed.
Old Aug 31, 2004
dirtySAMURAI's Avatar
I log in from time to time
Don't worry about it. If you still have that little tube thing in the back of the headlight, all the moisture will seep out of there and you'll be fine. Just don't get so damn worked up about it.
Little things like this should be searched for..
Old Aug 31, 2004
civic02ex's Avatar
got banned
It's going to suck taking the headlights out to put silicone on them because I would have to remove my entire aftermarket front bumper and be extremely careful with the foglights. But I'll probably have to do that soon anyway to prevent this from happening again. I just thought that TYC were very good quality and that I would not have to do all the extra stuff since that is what they claim as they make factory parts as well, (that is why I specifically purchased TYC) but I guess I was wrong!
Hey FaiJai,
So do the projectors unfog? Will they return to their natural state or will they remain damaged? That is my main concern right now.
Thanks!
Old Aug 31, 2004
MegaHurtz's Avatar
Waht does this post have to do with audio or electrical?
Old Aug 31, 2004
FaiJai's Avatar
ahhah seriously mega hurtz...somebody move it to lighting.
Civic02ex: with pass experience it will unfog but if you want it to do it quick use a hair dryer to clear it out or just leave it out. hope that helps
Old Aug 31, 2004
yea.. just let it dry out, using whatever method you want, then just use a heapload of silicone on the "seam" where the lense and the housing meets...you can buy a small tube of water/weather proof clear silicone at walmart for like... 3 bucks.. i did that even before i put my lights in and my car has been through a little piece of hurricane charlie and gaston (that was actually a tropical storm) and a constant ~100% humidity and i still have no fogging...
Old Aug 31, 2004
doubledeuce2k2's Avatar
my lights would fog under the most extreme humidity (cleared stockers) but my bulbs blew once after almost 1.5 yrs. whatever...
Old Sep 1, 2004
gotrice's Avatar
gotrice will become famous soon enough
i had the same problem once and all i did was expose them to heat like a hairdryer or shove them them in the oven but not set too high or they will melt and i had them worse but it went away the next day and hasnt happened since.
it did start to look embarrassing since it was like 90-100 degrees and my lights are sweating. i remember someone once saying "damn is that hot out here" looking down at my lights
Old Sep 1, 2004
xam's Avatar
xam
snooty patooty partier
xam has a spectacular aura aboutxam has a spectacular aura aboutxam has a spectacular aura about
**** on them, if its in the inside then put in oven for 10 minutes on 450 degrees and then **** on the inside after u open it. wathc out now its hot!
Old Sep 1, 2004
FALKEN's Avatar
Civicforums Junkie
moved to the I.C.E. & Electrical...Subforum: Lighting
Old Sep 2, 2004
Civic_2002's Avatar
Civic_2002 is an unknown quantity at this point
My projectors fogged up 2 after I installed them.
Just use some silcone but make sure its DRY DRY DRY inside the housing before you seal it up!
Old Sep 4, 2004
civic02ex's Avatar
got banned
Hey guys,
I appreciate all the replies. The good news is that my projectors have returned back to normal a few days ago. The fog went away. If this happens in the future, I'll know now that the problem will go away after a few days. Theres no way of taking out the headlights...I have this aftermarket front bumper on with fog lights in the bottom that it wouldn't be wise to keep taking off the front bumper..adjustment fit. But I am thinking of applying some silicone to the top part of the projector when I lift the hood up. But if I can't even do that, I think the headlights will hold up until oneday the bumper comes off. Once again, thanks for your help.
Old Oct 19, 2004
PunkingCivic's Avatar
I need TP for my bunghole
Snaps
My tyc's just fogged yesterday when it rained.
It just sucks that you pay 200 bills for lights that will fog.
Old Oct 19, 2004
Civic_2002's Avatar
No problem, if you have time. Just take off the projector and reseal it.
Or you can try to reseal it without taking it off.
Go to your local harware store and get some silicone, water proof...Perhaps for tiles. They come in clear, black, white....That should do it. PM if you need more help....
UltraHDGames
Jun 8, 2016 05:16 PM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
