168 LEDs - superbrightleds.com
ok so on their site there are one bulb, four bulb, and six bulb LEDs
does anyone know how they look, i have hte one bulb ones in my headlights and they are dim, if i got the six bulb ones for outside and the four bulb ones for inside will they be too bright or should i be ok?
Yes, it's an Acura EL
I had 6LED ones in my front corners before, and they looked OK, but the beam was very low-angle, so you could really only see the light from directly in front of the car. Even from the corners you can't see them. From the front though they're pretty bright. I have 4LED ones in there now and they look pretty good as well.
LEDs are just not designed to work like bulbs. You can see them fine from straight ahead, but they won't reflect in the housing or from the side. Best bet is stick with bulbs.
Someone with more spare time than me could whip up some custom bulbs using Luxeon Star side emitting LEDs. That way you would still be using the reflector to refract the light where it's supposed to go. Anyone here that bored? lol
frank_kleng
Sep 29, 2015 10:55 PM
MamaBear2015
Sep 24, 2015 11:34 AM
Klame9420
Sep 18, 2015 12:37 PM
