Instructions for putting HID in stock TYC???
Old May 9, 2004
silverem2's Avatar
Ok, so this will apply to anyone who has installed a hid system in thier STOCK tyc projectors.Probably someone like Impulse. I am wondering what is all involved in the process as i am ordering a hid kit on monday. I will EVENTUALLY order projectors to replace the tyc projectors but not right now, if someone can give me a rundown in how hard this is, please, let me know
thanks
Old May 9, 2004
ImPulse's Avatar
if u are getting an aftermarket HID kit, get H1
http://hidforum.com/diy/h1.php
I dont know what kit you are getting so, I cant explain how to install it. I can show you where to put the ballasts.
Old May 9, 2004
silverem2's Avatar
Its a helios kit. Im just wondering seeing as you at one point had the hid in your stock tyc, im just wondering how you personally did it. Like is there any wires that i have to splice or anything? Like how hard exactly is it to put the hid bulb in, on the projector?anything you can tell me will be helpful. Thanks
Old May 9, 2004
ImPulse's Avatar
I dont have an aftermarket HID kit... So, all i had to do was sodder 2 wires/ballast and that was it for the wiring. The other stuff, well, thats my secret
Old May 11, 2004
TMRakip's Avatar
TMRakip is an unknown quantity at this point
What's the best way to crack those TYC ****ers open? That's my only problem before I start doing mine...
Old May 11, 2004
silverem2's Avatar
ok, where should i put the ballast/igniters?
Old May 11, 2004
ImPulse's Avatar
hmmm, Hard to explain but you gotta have the front bumper off, and they go by the fenders. Ill take pictures for you of what I mean.
Best way to crack the TYCs open is to,
Turn oven on at 320 degrees - then turn it OFF
Make sure coils are NOT RED (ON)
Then place TYCs in the over away from the coils for 5-8 minutes
Wear mits because your hands will burn and the silicone they use will get on you and burn you
Then just use a butter nife to unclip those lil clips, and pull it apart.
I would keep the TYCs in the oven for 4 minutes and if it doesnt seem to come apart just do it again for 8 minutes. Its better to wait then to **** up a $200 product.
Old May 11, 2004
ren808's Avatar
ren808 is on a distinguished road
Im thinking about installing hid in my tyc projectors. i got a few questions? if i buy a used hid kit that was on a audi bmw acura etc etc.....how hard would it be to install in the tyc projectors and by saying this i mean the swapping of the lenses and the internal parts, if it is involed in the process. im asuming that each lens and internal componets are diffrent from every car, what used hid system is the closest match?
Old May 11, 2004
Rufus's Avatar
Ren, thats what I did. Impulse retroed too I believe. Here's a rundown of the process. Aftermarkets are nice because they're plug and play. The downside is that you're limited to the characteristics of the projector that came with the headlights. Since most of us "in the know" already understand that, we opt for an actual retrofit (factory HID setup from another car). Mine are from an Audi S4 and are retroed into the SONAR projectors. Opening up the lights can be done in whatever fashion you chose. I used a heat gun for mine. Once you have them ope, 2 issues exist. Installation of projectors and installation of a wiring harness. I won't get into the harness as there are a million sites on the internet that tell you how to do it, but I will say this: you cannot plug them into your stock harness. HIDs require more power to ignite the ballasts. Mine are hardwired to my optima and relayed back to the harness. Part 2 is fitment. Use your brain, every setup will be different and you'll need to make sure that they sit even in the housing as it will effect your cutoff line (which makes those pretty colors you all love) Eack light has one, so you have two lights to make even. It's not as easy as it sounds as mine have been off by about 3" for a year now. Luckily my projectors fit almost perfectly onto the Sonar projector mounts. I just had to make a post to hold the top of the projector back. So I already had fitmant, I just needed to adjust height on both. Seacrest Out.
Old May 11, 2004
silverem2's Avatar
ok, i got the h1 hid on the way, most of that should be plug and play into my STOCK and i repeat, STOCK Tyc projectors right?
Old May 11, 2004
silverem2's Avatar
and they will also be brighter than my halogen bulbs in my projectors right? Like hid will be brighter in the projectors than the halogen bulbs?
Old May 11, 2004
Rufus's Avatar
HID is inherently brighter so you've got one question answered right away. How it shines on the road and how it looks throught the projector is once again a characteristic of that projector. All I can say is best of luck.
Old May 11, 2004
silverem2's Avatar
impuse had hid in his with his stock projectors, how did that look? was it brighter than when you had halogens?
Old May 11, 2004
silverem2's Avatar
anyone?
Old May 11, 2004
Rufus's Avatar
I cant answer this one. I knew how bad those projectors suck with halogens. Thats why I wasn't interested in a H1 Kit.
Old May 11, 2004
Rufus's Avatar
Old May 12, 2004
ren808's Avatar
I just order a new set of tyc projectors because my car got hit with a foreign object while driving on the expressway. now car looks like it has a black eye. anyways im gunna take that one bad projector apart and play doctor.
RUFUS, is the s4 projector the closest fit as in lens diameter or did you just choose to use the s4 projectors?
Old May 12, 2004
ImPulse's Avatar
The Sonar projectors Rufus has, Uses larger aftermarket Lenses (I believe) I had a pair of projectors that had a "waffle" pattern on them, and the projector lense was 2x's the size as the tyc lens.
TYC Projectors (What I have) Use smaller aftermarket lenses
So, If you get the projectors that Rufus has, You can put either A4 or A6 projectors in it.
If you get TYCs you can just fit A4 projectors in it (while making it look "oem").
Regarding light output, Obviously, the bigger the lense the more light... So, an A6 projector will give more light than an A4's.
Old May 12, 2004
ImPulse's Avatar
The question of, Is halogen fine in projectors? Everyone has different opinions. Honestly, If they are aimed correctly and If you have a decent halogen bulb, They will put out the same light-output as oem.
However, If you line up a civic with halogen projectors to an HID projector, Well, The Projectors with the HIDs will most likley cover the light out-put of the halogens LOL (meaning the HID will literally take over ~ Main reason for me laughing while passing people @ night time that use halogens). Just funny to completley turn everything into daylight ^_^
Old May 12, 2004
ImPulse's Avatar
Yes, With the HID kit it will be brighter... But at the same time there will be glare, and If there is A LOT of glare, then you will be getting high-beamed a lot, and having a risk of getting a ticket if its too "colorful". Basically, I Would AIM the projectors with the halogen bulbs first. Then after everything is aimed correctly, install the aftermarket HIDs.
Yea, I had an H4 kit in my OEM housing, It was brighter than halogen but was also blue'r. The bulbs actually popped within a month so, Thats the reason for me going OEM.
Old May 12, 2004
silverem2's Avatar
awsome, i dont care if i get highbeamed or the cutoff isnt perfect, as long as its going to be brighter with hid in my projectors than with regular bulbs
thanks
Old May 12, 2004
Rufus's Avatar
The TT projectors are the smallest Audi makes. The S4 or a4 fit well and were almost indentical in mounting location.
Old May 12, 2004
silverem2's Avatar
so there wasnt much that youy had to mod then?
Old May 12, 2004
Rufus's Avatar
Not really.
Old May 12, 2004
silverem2's Avatar
you still had to cut out the back tho correct?
Old May 12, 2004
Rufus's Avatar
Here's what they looked like when I finished them initially.
Old May 12, 2004
Rufus's Avatar
Since then I've painted the bezels the NBP to match the car and put in another halo.
Old May 12, 2004
silverem2's Avatar
now, what will i have to wire so that when i turn the hid on and i wanna flash my brights the hid stays on?
Old May 13, 2004
Rufus's Avatar
Well........
I didn't want to get into the harness....but
as far as the brights go: You simply wire a one way diode into the harness. This way when the lights are on it doesn't send power to the brights, however, when the brights are on it feeds power to the HIDs. This is simple.
Old May 13, 2004
silverem2's Avatar
can you make a paint diagram or something, im sorry, im just not extremly electrical inclined lol
