Hid Help!
Old May 4, 2004
illusive02civic's Avatar
illusive02civic is an unknown quantity at this point
Hid Help!
I recently bought some KAtz HID H4 and was trying to install them onto my HOnda civic 2002. But for some reason I couldn't get them to work. All the connections were right. I know they work cuz i connected them to my friends car and they worked fine. Does anyone have any clue of what I may be doing wrong?
Old May 4, 2004
ImPulse's Avatar
check fuses... upgrade to 20 or 15
Old May 4, 2004
Thanks I'll give that a try!
Old May 5, 2004
Would up grading to a 30 be to much? Cuz I tryed that n it didnt work.
Old May 7, 2004
LiKEaFeRiO's Avatar
You should just stick with what is recommended by Catz.
And if your fuse wasn't blown then its probably not the problem.
Before you go through with installation, connect one ballast, ignitor, and bulb in its holder along with the wires to the battery to test to see if the bulbs light up. Then try the same thing ni your friends car just in case its your car that is the problem, which I highly doubt.
Some trial and error by switching ballasts, ignitor, and bulb should eventually lead you to the cuase of the problem.
UltraHDGames
Jun 8, 2016 05:16 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
Voiceofid
Feb 3, 2002 03:54 PM
