need headlight help
Old Mar 16, 2004
need headlight help
Okay, so lately people have been brighting me at night. I had to change out one of the headlight bulbs, so would this cause them to be aimed wrong? What's the correct way to make sure the aim is right? I know HOW to aim them, just need to know what to do as far as making them at the proper level. Thanks...
Old Mar 16, 2004
Gee thanks for the help.
I spent an hour trying to adjust them, but no matter what one side is brighter. Even if they're at the same level. So I just aimed them down more and they're not exactly even. Looks good enough.
Old Mar 16, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
to tell you the truth its hard what i did what i park close to my garage and from there i start the aiming its hard. unless someone has a better method.
Old Mar 17, 2004
FALKEN's Avatar
Civicforums Junkie
did you try to adjust them from side to side??
Old Mar 17, 2004
How do I do that? It only shows place for up and down.
Old Mar 18, 2004
zen_master's Avatar
isn't that the right side of the headlight always brighter than the left side?
the right side supposely brighter in order for the driver to be able to look at the signs easily....and the left side is lower so that it wont bug the other driver from opposite line..
ANYway....i'm looking for a replacement for headlight..
is there any suggestion for any headlight other than the OEM which use the normal bulbs configuration as the OEM? using 9003, turn signal and the small bulb... (not projector headlight)
meicalnissyen
Sep 25, 2015 12:12 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
