help me with moist!
Old Mar 15, 2004
zen_master's Avatar
help me with moist!
guys!
suddenly, after doin a car wash in deltasonic, my right side headlight got some moist inside of it...
is it possible because i didn't properly close the plastic when i install my silverstar?
any idea how to remove the moist and to prevent that from happening again?
need help ASAP! thanx!
Old Mar 17, 2004
FALKEN's Avatar
Civicforums Junkie
have you had the housings opened??
Old Mar 17, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
in order to stop that you must reseal it again with some silicone, but is it aftermarket headlights or stock, but what i did was i use black electric tape, and i tape up all the part that was opening due to TYC shitty job a seal it. its better than silcone more clean. if its ur stock i say take it in for a warranty and see what they say. eventually it will dry up but with water marks,
Old Mar 17, 2004
zen_master's Avatar
thanx for the infos, guys!
i got a stock headlight....i'm afraid that the moist happened because i didn't properly close the weather seal when i installed my sylvania ST...
the moist's gone after i drove my car for hours with my lights on....well, in the night...of coarse... i think i will re-check everything again...
the problem only occured on the right headlight....i think i re-check the left headlight so many times because it's pretty hard to close it on that side due to the oil bottle..
edit:: do u think they will be happy to fix the headlight after i changed the bulb?
anyway, originally, the problem occured after doing a carwash in deltasonic...i assume..
YYZRush747
Exterior
37
May 10, 2019 06:22 PM
rileyb22
Dec 26, 2011 04:38 PM
zen_master
Lighting
Mar 26, 2004 09:06 AM
sL3epy
Mar 9, 2004 06:15 PM
