Need help with TYC's ASAP!!!
Old Mar 13, 2004
gotti's Avatar
Exclamation Need help with TYC's ASAP!!!
!@%!#@$!#@@#!$E!@$!@$!@
Ok, I decided I was going to switch out my h1 bulbs for a nice set of xenon-like bulbs. I find the size, put those biatches in.
Now...the passenger projector will barely light up...the driver side one is fine. However, now the highbeams go on with my projectors. Also, my indiglo gauges are hooked to my lowbeams and they barely even light up. Is it a bad ground? Bah, I cant drive like this tonight. I guess I'm gonna have to look at it in the morning in the daylight.
Old Mar 13, 2004
I don't understand how switching the bulbs could suddenly cause that. Either the bulbs suck, or they're high wattage and ruined your electrical system.
Have you tried putting the stock bulbs back in?
Old Mar 13, 2004
silverem2's Avatar
ya, id say possibly your running too much power off your headlights, find another place to run the indiglows do
Old Mar 13, 2004
gotti's Avatar
eeek. the things are 100w. Too much?
Old Mar 13, 2004
If they are true 100W bulbs, that is WAY too much! I hope you didn't use them for more than a few seconds. If you really want to run them, you need to upgrade your headlight wire harness. Also remember that higher wattage bulbs inherently burn out faster.
Here are some links for the wire harness. You can buy one, or just make your own.
http://suvlights.com/
http://www.rowand.net/Shop/Tech/Wiri...ightRelays.htm
Old Mar 13, 2004
Kloverz's Avatar
Kloverz has a little shameless behaviour in the past
check ur fuse this have happen to me before.
Old Mar 13, 2004
gotti's Avatar
Bahhhh dammit. I can't find the stock bulb either. I'll just return them and say they're the wrong size :-x
thanks for your help guys.
Oh yeah, I ran the one bulb for almost 3 hours
Old Mar 14, 2004
silverem2's Avatar
ya, i suggest that you change them immediately, whether or not you believe that they will damage your harness, they will, the reason they have not to most people is cause they dont leave thier brights on that much, if you left them on all the time they would burn
Old Mar 14, 2004
Voiceofid's Avatar
End Bringer
sounds like fuse
when my fuses go, it leaves the low beams barely running, but turns on the high beams
now, the hid will flicker(BAD) with the highbeam on, when the fuse goes...
Old Mar 14, 2004
gotti's Avatar
Where is the fuse for the bulbs? Is it in the engine fuse box ?
Old Mar 14, 2004
ImPulse's Avatar
^ yes, read the little symbols... should say left or right headlight
Old Mar 14, 2004
gotti's Avatar
Aight man, thanks. You guys rock.
Old Mar 14, 2004
gotti's Avatar
It was blown. Ok, so you say 100w is too much. Should I just return the light bulbs, or can i keep the 100w. If I keep them, chances are it'd blow again...
bah
Old Mar 14, 2004
silverem2's Avatar
return and get safer ones
Old Mar 14, 2004
Or get the upgraded wire harness as I said above. But I would just get stock 55/60W bulbs.
Old Mar 14, 2004
gotti's Avatar
Yeah, im too lazy to get some new harnesses. But thanks for the links anyway. I guess I'll just go get some "less wattage" bulbs.
Old Mar 14, 2004
gotti's Avatar
I went back to the place and the guy said to just put some 20 fuses in opposed to the 15's. It works well.
Old Mar 14, 2004
silverem2's Avatar
does anyone know if anything bad can happen with that, what i understand that will do, is allow for more power thus causing more problems, because the fuse blowing is supposed to be a saftey for too much power running. Do you notice a differnce in higher wattage bulbs? I know when i had the mtec 4x they wernt any different than the 2x
just my 2cents canadian
Old Mar 14, 2004
Higher wattage bulbs pull more power to make them brighter. In an attempt to do this, the tiny stock power wires will overheat and eventually melt. You didn't see any difference because the stock wires can't supply the necessary power to the bulbs.
Old Mar 14, 2004
silverem2's Avatar
makes sence, but what do you think about the fuse thing, dont you think that it will cause something to wreck having a higher....just read my previous post about that
Old Mar 14, 2004
gotti's Avatar
I talked to guy who majored in Electronics through college and he said if I went 5 amps up in the fuse it wouldnt make a difference.
Old Mar 14, 2004
silverem2's Avatar
alright, just lookin out for ya, in case somethin happened
Old Mar 16, 2004
gotti's Avatar
word
