TYC Halo ?!?
Old Feb 10, 2004
AlienX's Avatar
AlienX will become famous soon enough
TYC Halo ?!?
Has anyone put halo's on their TYCs... I was wonding if it was hard, and maybe seeing some picture ?
Old Feb 11, 2004
AlienX's Avatar
ttt...
Old Feb 14, 2004
dirtySAMURAI's Avatar
I log in from time to time
b390lu or something along those lines did this a while ago. he said he used EL (electro luminescient) tape, but don't quote me on this. he went to a shop to get it done correctly.
Old Feb 14, 2004
ImPulse's Avatar
Well, When i had my tycs apart I took a window rod and bent it into a peftect circle, and well.. Its too thick, and will not fit (around the projector). It will however fit around the high-beam area but, I dont think it will look right IMO.
Infinitie is right, Someone on the forum (or a couple) have used el cable/neon wire. The only problem with this is, you may not get a perfect circle. Plus, IMO when the neon is on/off it doesnt look that great =\
When i was sufin clubrsx.com i saw a member there that did the neon wire retro and it looks like ****, lol. Ill see if i can get the pic
Old Feb 15, 2004
AlienX's Avatar
blah, I want to try this out ( not EL ) but I just need some extra info.. I think with a thinner rod it should be possible.
Old Feb 15, 2004
ImPulse's Avatar
well, the only rod that i know of (that will also allow light to reflect around to give a "glow") would be the curtain rod. Maybe cut it in half some how? IDK, just remember that halo works be having the light reflected inside the plastic.
Old Feb 23, 2004
AlienX's Avatar
i know.. i was going to put a light etch in it so that it would reflect the light.. otherwise it will just be bright in one end and no colour in the middle...
wingsfan19
Oct 1, 2015 03:45 AM
carid
Jun 5, 2015 11:51 PM
pdxbiker
Jul 11, 2002 07:13 PM
Player1
Jul 8, 2002 11:49 PM
FlippedOut
Jun 19, 2002 12:16 AM
