Good or Not
Old Feb 22, 2004
hondacivic218's Avatar
hondacivic218 is an unknown quantity at this point
Good or Not
Are these Good for a 03 Civic? are they Bright?
http://216.82.69.117/detail.asp?PRODUCT_ID=HC01PHCC-G2
Old Feb 22, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
The headlamp housing has very little to do with brightness, brightness is determined by your lightbulbs.
Personally I do not like aftermarket headlamp assemblies, they are too expensive and the appeal only lasts for a while.
Old Feb 22, 2004
civicstyle82's Avatar
civicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to all
Those units are very nice, if I had the money I would get some projectors but I have to buy other things for my car first.
Old Feb 22, 2004
chocobo15_2000's Avatar
§C§H§O§C§O§B§O
chocobo15_2000 is an unknown quantity at this point
^^^^ werd
housing has HUGE affect on bright-ness...if your housing cannot focus light, it doesn't matter how bright ur bulb it, the light will diffuse, and look dull...but if you have focused light, u can make candle light look like something comming from a lighthouse ^_^ (exaggeration)
Old Feb 22, 2004
Crashoveride's Avatar
Crashoveride is an unknown quantity at this point
Those are nice lights, there are a few things that will help make these a good upgrade, not only do they look sweet, they will also be brighter because they are projectors as well as the housings are more reflective than stock, matched with a good set of bulbs they will make a big difference in brightness.
When buying these just make sure they are from a reputable dealer / manufact. just in case they start to leak or fog up, that way you will have warrenty on them.
Crashoveride
Old Feb 22, 2004
aznrj's Avatar
aznrj is an unknown quantity at this point
i'm pretty sure replacing to an aftermarket headlight will not be as bright, even with expensive bulbs. converting the projector to HID on the other hand is a whole different story. - BUT IT'S STILL NOTHING COMPARED TO RETRO-FIT HID CONVERSION HEADLIGHTS.
oh you btw with those "halo" rings, FYI if you DO NOT correctly install/wiretap them in place, you run a big risk in buring out your parking light. you'll have one of those days where you headlight turn on but no turn signals or parking light. you'll then either have to replace the fuse or find the portion of the wiring thats been burnt and replacing it is a biiiaaattcchhh...
Old Feb 22, 2004
aznrj's Avatar
Crashoveride
just cuz its projector don't mean it'll be brighter than stock. its just a different style housing. and they are definitely NOT going to make a big difference in brightness with a good set of bulbs, even with PIAA. you would have to convert to HID for a significant difference.
Old Feb 23, 2004
FALKEN's Avatar
Civicforums Junkie
moved to I.C.E. & Electrical...Subforum: Lighting
czarlun
Jun 20, 2015 08:55 PM
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
