ebay headlight problem
Old Dec 2, 2003
jdmb16ahatch's Avatar
jdmb16ahatch is an unknown quantity at this point
got these headlights off ebay and the plug for the turnsignals are 1557 bulbs and the stock plugs wont plug into the hole... the stock bulbs wont go into the spot in the new headlights either...and the parking light also uses the older style plugs has anyone run into this problem...if so anyone have a solution?
Old Dec 2, 2003
fine02civicgurl's Avatar
*BoY*CaR* *GiRL*DRivER*
fine02civicgurl is an unknown quantity at this point
i absolutely want to throw my computer out of the freaking window when i type a long reply and hit send reply, and i get the "page cannot be displayed" and its NOT my computer. but i wont get into that.
anyway, post a pic or link to the lights. the headlights are prolly H1's, not H4's, which is factory bulbs. im surprised the lights did not come w/bulbs, mine did, from ebay. anyway, they have a thread that shows a pic of the back of the light w/the right numbers for bulbs. etc
Old Dec 2, 2003
nah its not the headlight bulbs they are the same its the parking and turn signals that are different
Old Dec 2, 2003
TeLLy's Avatar
Yes, it's an Acura EL
Park/signal bulb connectors are slightly different between sedan and coupe, could that be it? Is this a matter of the hole being just a little too small, or is the opening drastically different (ie the retaining tabs are totally incompatible)?
Old Dec 2, 2003
post a pic of them
Old Dec 2, 2003
2k3HonCivicEX's Avatar
2k3HonCivicEX is an unknown quantity at this point
possibly 6thgen headlights, or i dont know.... post pics
Old Dec 2, 2003
cant post pics dont have a digital camera here...the holes on the parking and turnsignals are drastically larger and dont use the same bulb for the turn signal parking lamps are also larger but still use the 194 type bulb...not 6th gen i know the difference...i dont know what the difference between 4dr and coupes are is that possible the 4dr use different sockets for the turnsignals and parking lamp? as for the retaining tabs the stock ones are too small for the new housings ima see what i can figure out but do the 4dr ones fit onto the coupes if not im SOL
Old Dec 2, 2003
well can u find them on ebay and link us. no one really knows what you ar talking about
Old Dec 2, 2003
TeLLy's Avatar
Yes, please show us these lights. Are they stock, modified stock, aftermarket, JDM?
Old Dec 2, 2003
i cant get on ebay here but if u go there look up titanium jdm headlights i thin that should get u there they look like the jdm type r ones
Old Dec 2, 2003
D5cIvIc's Avatar
the headlight that u got off of ebay are for a sedan. i went to PROCARPARTS and paid them a visit before i bided on them and made sure if the headlights they were selling were for a 2 door or a 4 door. and it turns out that all the ebay gunmetal headlights( if thats what ur talking about) are for the four doors and not hte two. so if you have a coupe then thats the problem. but if u have the sedan and they still don't fit then i don't know. besides if u have hte coupe and the parking light and signal lights won't fit just buy new sockets for them if u don't want to get rid of ur new headlights.
Old Dec 2, 2003
TeLLy's Avatar
Exactly!
Old Dec 2, 2003
acidbaby's Avatar
The Beez Kneez
go to auto zone or pepboys and get some automotive goop its some strong silicone sealer for cars it works great.. then just go ahead and tak the whole headlight off ,(it will make it easier if you do).
then all you have to do is take the little rubber peice that is used as a seal off .. then you need to take the peice that connects to the bulb off, not just from the bulb the wire disconnects from itself also.. you will have to do this ne ways because the damn thing will fog up like you wont believe... seal it up with the silicone and let it sit for 2hrs..
and vwala your done you have also just bypassed the biggest problem with these damn headlights also... now they are sealed
Old Dec 2, 2003
acidbaby's Avatar
The Beez Kneez
all the 7thgen haedlights are the same foo except 2004 its all the same setup
if it wasnt it would take a different bulb
Name:	lights at night 7thgen.jpg
Old Dec 2, 2003
TeLLy's Avatar
Hey acidbaby, have you looked at a sedan headlight versus a coupe? No need to call the guy a foo, he's asking a legit question.
Coupe - sealed with black goo, held together by little metal clips
Sedan - sealed with grey (harder) goo, held together by integrated plastic clips
Yes, the bulb sockets are slightly different in size, hence his current problem. But it's true the bulb type numbers are the same.
The difference goes all the way to the orange lens you take out when clearing. Even the tab locations are different between the two, so an orange lens from a coupe will not fit on a sedan, and vice versa. How do I know this? I've cleared plenty of headlights, both coupe and sedan.
Old Dec 2, 2003
acidbaby's Avatar
The Beez Kneez
but the solution still will work its what i did
Old Dec 2, 2003
streetglower's Avatar
I agree with acidbaby, the headlights the headlights for the coupe and sedan are the same, I have even asked honda and they said they are the same headlight, basically the headlight that was ordered off of ebay probably is a crappy headlight, I have ordered headlights from procarparts and the sockets were bigger and the stock socket pieces wouldnt fit into them, just have to make it work.
Old Dec 2, 2003
acidbaby's Avatar
The Beez Kneez
werd
Old Dec 2, 2003
TeLLy's Avatar
Sigh. I give up.
Old Dec 2, 2003
ok i figured it out the sedan uses different plugs on the headlights for the corner and parking lights from what i saw at the gym.... on a 4dr so ima use some plugs that will fit from another honda at the junkyard and yeh u get the picture thanks
Old Dec 2, 2003
SMURF_KILLER's Avatar
SMURF_KILLER is an unknown quantity at this point
wow telly has nice pic of big butt
Old Dec 3, 2003
acidbaby's Avatar
The Beez Kneez
nice observation you just lost one point
Old Dec 3, 2003
FALKEN's Avatar
Civicforums Junkie
moved to I.C.E. & Electrical...Subforum: Lighting
Old Dec 3, 2003
ok just one question for anyone who can help with the turn signal plug is the harness on the turn signal of a 4dr different than the coupe? i dont wann order the harness for a 4dr from honda and not be able to plug it into these lights. i know the parking light is different so im asuming the turn signal is as well?
basically does the 4dr use an oval shaped plug for the turn signal harness plug?
Old Dec 3, 2003
OK i figured out that my 03 uses different plugs than an 01 for the harness this is what im thinking anyways but on majestic honda the part #s are the same so yeh the plug on the new headlights for the tunsignal is an oval mine are square
Old Dec 3, 2003
acidbaby's Avatar
The Beez Kneez
just do the mod i told you about it works great and it only takes like 2hrs with drying not as much trouble.. you are saying that you are going to replace the whole harness?
Old Dec 3, 2003
im not gonna put them in with silicone what happens when u need a new bulb? or want to put ur stock headlights on? im gonna change the plugs for the parking lense they are different on the 4dr and the 4dr are the same as the ones i have....but the 4dr harness plug is the same on both cars for the turnsignal so im thinking i just need the plug for the bulb from a 4dr to make it work
Old Dec 9, 2003
well the parking light socket from the 4dr works in the headlights and the turnsignal socket is just a tiny bit to small from the 4dr so ima have to seal it up like he said oh well
Old Dec 9, 2003
acidbaby's Avatar
The Beez Kneez
you can still replace the bulb if you want. it will come undone! silicone is like rubber.
Old Dec 9, 2003
D5cIvIc's Avatar
donīt be calling anyone a foo when u donīt know what ur talking about. i clearedm any of my firends headlights and teh sockets are different from teh sedan adn the coupe. so why donīt u research this before u start running ur mouth homeboy.
