h1 hid conversion owned
Old Oct 25, 2003
Voiceofid's Avatar
End Bringer
save your money, and do the **** right, get the true hid projecots and retro fit them
here's my friend's celica owning me... i am in the process of getting oe hid projectors..
Old Oct 25, 2003
Voiceofid's Avatar
End Bringer
that's also xenodepot.com 5500 h1 vs xenodepot.com 4500 h7
Old Oct 25, 2003
CoupeStylz's Avatar
Si(R) killer # 1
CoupeStylz is an unknown quantity at this point
It's all about the focusing of the beam. I don't know the specifics of your setup, but if it is possible, move the HID bulb back farther away from the projector lens, closer to the parabolic reflector in order to focus the beam farther ahead.
-that's a really good picture BTW, the one from behind the car.
Old Oct 25, 2003
dragoon's Avatar
just aim your beam up.
mine was actually too far ahead and i had to angle them down.
Old Oct 25, 2003
player's Avatar
from what i see, it seems your lights are not reflecting arounf enough. i think u need to aim this better
Old Oct 26, 2003
Voiceofid's Avatar
End Bringer
you guys don't realize, that's so far up, that it's hitting the tree tops!
Old Oct 26, 2003
ImPulse's Avatar
lol... owned >=]
Old Oct 30, 2003
JayFReaZy's Avatar
Re: h1 hid conversion owned
Which projectors do you have, TYC or Halo? Im thinking even if the ceilica's HID's are brighter, im sure you have noticed a signifigant difference from the reg halogen to HID's in your projectors right?
Old Oct 30, 2003
SLAMMED01CIV's Avatar
SLAMMED01CIV is an unknown quantity at this point
Those headlights need to be aligned properly!!!!! Your right headlight is way too high and your left one is way too low. Also your beam patterns are on top of one another. They need to be spaced further apart. That is why the light out put is so poor. That and because yours have a higher Kalvin rating then the ones in the Celica. The higher the Kalvin rating the lower the Lumens (light out put). 4500K owns 5500K
Do a bit of adjusting and you will notice a world of a difference.
One more thing. Your friends need to be adjusted as well. His are a tad bit too high. There is way too much glare coming off those lights.
Old Oct 30, 2003
dragoon's Avatar
i've hit rooftops of 1 story houses with mine before i angled them down.
Old Oct 31, 2003
Voiceofid's Avatar
End Bringer
i can show you the same thing with my 4500k kit
angel them down didn't help anything at all
i can't see how you people can see with these lights, a bmw drives by me and all my lights disappear!
his car has no glare at all, that's just how it looked on the camera
Old Oct 31, 2003
Voiceofid's Avatar
End Bringer
even our beam pattern is way different (Refer to the fact that we have fog light projectors)
Old Oct 31, 2003
B390LU's Avatar
B390LU is an unknown quantity at this point
Here are the 2 pics I took of my TYC projector headlights with H1 Ichikoh Velias HID I imported straight from Japan. It's 4300K and quality is in par with Catz/Bellof and Raybrig. This company makes HID kit for Lemans and also created the Subaru STI headlights and HID system.
I was going to do the OEM projector lens retrofit but resources for the parts are not that good since I'm located in Australia so I decided to just install good quality HID kit into TYC.
Beam pattern from inside the car isn't so desirable but my goal which is to have cool looking HID lights without blinding oncoming traffic is accomplished.
Let's make this thread a good discussion place for people with HID and also those who are looking to buy one.
Old Oct 31, 2003
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
It all boils down to... If you want the best beam pattern and color... you have to get OEM projectors and D2S bulbs... the TYC projectors ARE NOT DESIGNED FOR HID
Old Oct 31, 2003
2k3HonCivicEX's Avatar
2k3HonCivicEX is an unknown quantity at this point
i would have to agree, but the beam coiming out of B390LU's projectors is by far better thatn that coming out of my aftermarket bulbs in stock housing.
Old Oct 31, 2003
Voiceofid's Avatar
End Bringer
it "looks" good, that's what mine looks like right now after i reaimed them
Old Oct 31, 2003
B390LU's Avatar
voiceofid:go somewhere where there's no lighting around and take pics from the same angle as in my 2 pics so we can compare.
Old Oct 31, 2003
The beam pattern and brightness when I had my HID kit in my TYC projectors looked exactly like B39OLU's. It was very bright and the cutoff was immaculate. It is all in how you align the projectors as I have been saying all along. Voiceofid, you just need to take a while to adjust them PROPERLY. Yours aren't even close to properly adjusted. If you do a search on this site you will find many threads on how to adjust them properly. If you can't find any and you still need some help, PM me. I will talk you through it. I have helped quite a few people on this site with the retrofit and adjustment of their TYC HID's.
Old Oct 31, 2003
Voiceofid's Avatar
End Bringer
here's my contributions
Old Oct 31, 2003
Voiceofid's Avatar
End Bringer
front
Old Oct 31, 2003
Voiceofid's Avatar
End Bringer
i couldn't get a perfect copy, because i only went down the road and took the pic in the darkest road around here, and bothsides are grass and trees, wasn't about to venture to snake infested grass in the middle of the night :-p
Old Oct 31, 2003
Voiceofid's Avatar
End Bringer
instead, i took 2 pics of it
Old Oct 31, 2003
Voiceofid's Avatar
End Bringer
i am waiting for my plug and play to oem bulb conversion harness to arrive, once i have them i will also show pics of the compareson between the rs6 projector, verses our projectors
i never said the cut off was anything wrong with it
but don't you people notice the lights don't go far? look at my pics, compare to my friend's projectors, it barely goes the distance
here's the pics of my projectors (also in the other hid thread in tech)
Old Oct 31, 2003
Voiceofid's Avatar
End Bringer
ah, and tell me how you guys' light compare to this true hid?
that's a retrofit, it's only one head light, that's why it looks a bit odd
Old Oct 31, 2003
Voiceofid's Avatar
End Bringer
Re: Re: h1 hid conversion owned
yes, it does make quite a difference going from halogen to hid, but true hids in true hid projectors still dwarf me, big time. i have tyc
Old Oct 31, 2003
cdmx's Avatar
What kind of headlight do you have??
Old Nov 1, 2003
Voiceofid's Avatar
End Bringer
the projectors i posted above are rs6 projectors, they are twice the size of the tyc projectors, though
otherwise, i am currently using tycs with 5500k h1 hid from xenondepot.com
Old Nov 3, 2003
Voiceofid's Avatar
End Bringer
i put my 4500k back in, and also took some pics
Old Nov 3, 2003
guamcivic2k1's Avatar
YoUnG N SuXsExFul
those are pretty bright
Old Nov 3, 2003
Hefe's Avatar
2 feet in front of the car..
