Rear Sway Bar
Old 02-11-2007
PitchBlack's Avatar
PitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nicePitchBlack is just really nice
Rear Sway Bar
I just installed a Progress rear sway bar on my 02 LX Sedan yesterday. My car is lowered on the Progress drop springs as well. My problem is that the rear end has developed a "bounce" when it go over bumps. For each bump I hit the rear end bounces about 2-3 times. Besides this my car isn't nearly as low in the rear as it had been. Is there a way to put the sway bar on upside down? Any other reasons why a sway bar would affect ride height? Any suggestions or input would be greatly appreciated!
Old 02-11-2007
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
You can put the sway bar on upside down but it shouldn't affect height. Can you take a picture of it? If it's on wrong it's probably hitting the control arms which might be causing the ride height problem.
Old 11-18-2009
Mavrick272's Avatar
Mavrick272 is an unknown quantity at this point
Re: Rear Sway Bar
What did you have to do to get sway bars to work on your LX? I'm assuming that it didn't come with rear sways from the factory
Old 11-18-2009
Re: Rear Sway Bar
heres what it should look like installed the right way.
Old 01-06-2010
White97Bring's Avatar
White97Bring is an unknown quantity at this point
Re: Rear Sway Bar
To tell you my honest opinion. You need new struts. That will solve your bounce problem and you can forget all about that sway bar. Tip to all who read this dropping your car on old *** struts equals tons of bounce issues on civics.
Old 01-07-2010
Autocross Junky
Zzyzx's Avatar
Re: Rear Sway Bar
Yup, and a stiffer anti roll bar is just going to make this more apparent...
Old 01-24-2010
R3DL1N3's Avatar
Re: Rear Sway Bar
Right, you need better dampers. You're bouncing around because the stock struts can compensate for the new spring rate. Lowering the car only adds stress to your stock dampers.
pizzahutcombo
Suspension
07-13-2021 09:41 PM
juror
Suspension DIY
07-30-2019 03:28 AM
Marco83
10-13-2018 10:13 PM
GotSiR
06-23-2016 04:06 PM
muniorbust
33
08-31-2015 08:59 PM
Quick Reply: Rear Sway Bar
