Best manual transmission fluid?
Old 11-13-2011
bryan11's Avatar
bryan11 is an unknown quantity at this point
It's time for the first transmission fluid change. Should I use the Honda transmission fluid, Mobil 1 10W-30, or something else?
Old 11-13-2011
Trance Addict
MelJ's Avatar
Re: Best manual transmission fluid?
I use Redline MTL synthetic in my car. I love it. It really shines in cold weather, which is the main reason I bought it. Honda MTF isn't bad either. I think Amsoil makes an MTF as well. No hands on experience with it though.
Old 11-13-2011
04 Honda Civic's Avatar
I think putting motor oil for a manual transmission is ok. However its only for TEMPORARY purposes. I believe manual fluids have additives for the gears that engine oil does not have. I use OEM tranny fluid on my S2000. My Civic is an auto and I use OEM stuff as well. I think its more important to stick to OEM fluids for autos then for manual cars.
Old 11-14-2011
bryan11's Avatar
Looks like I'll stick with the Honda MTF. Redline lists a transaxle fluid with a much higher weight in their application guide, but that doesn't seem right to use a 75W oil when Honda specifies something 10W.
Old 11-14-2011
Trance Addict
MelJ's Avatar
It's the equivalent. It won't do anything to the transmission. You need to look at the GL number and other things. If you go on their site, it should explain it. I'm not pushing you to buy it, just letting you know that there's more to it.
Old 11-14-2011
pjb3's Avatar
pjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of lightpjb3 is a glorious beacon of light
I used Honda MTF. I have heard that GM makes a fluid for their manual transmissions that people on other sites like.
As far as using motor oil, I wouldn't. The pressure and shear forces in gears break down and wear oil differently than an engine. I'm not saying engine oil could not be used but I would want to see the manufacturer state that it is OK and the trany was designed for it.
Old 11-14-2011
Trance Addict
MelJ's Avatar
From what I've read from Honda, you can use motor oil for a brief period, but not as a substitute. Your description pretty much nails it.
Old 11-14-2011
EM2ti
maxtierney's Avatar
Royal Purple Synchromax MTF. Used Motul, good stuff, but a little too pricey for me.
Old 11-09-2014
trogfield's Avatar
trogfield is an unknown quantity at this point
TRANSAXLE IS NOT TRANSMISSION. automatic transmissions sometimes have gearboxes with gear oil.
Old 11-18-2014
broodfaun's Avatar
broodfaun is an unknown quantity at this point
For fluid, I always prefer to use OEM stuff.
BTW, anyone know how many quarts of MTF is required for 7th gen civic?
Old 01-04-2020
1st time Honda owner
EX2002Civic's Avatar
EX2002Civic is an unknown quantity at this point
1.6 or 1.7 I believe.
Quarts that is...
Last edited by EX2002Civic; 01-04-2020 at 07:21 PM. Reason: Forgot to specify 1 6 or 1.7 quarts
brags
17
04-08-2018 03:53 PM
Gibbenz
Transmission DIY
09-04-2012 09:48 PM
tweav88
08-04-2012 10:13 PM
KStorms09
Transmission
04-08-2009 08:43 PM
yourinmyw0rld
05-25-2004 12:30 AM
Quick Reply: Best manual transmission fluid?
