Speaker Problem
The only Wyoming Redneck on here
Speaker Problem
Sorry, just realized i posted this in the lighting section, maybe this will work better eh? So i put a new deck in my car, already had an aftermarket one just upgraded to one with built in xm. but now my front left speaker is not working. all my connections are good any ideas? btw my brother is having the same problem after he installed his.
Re: Speaker Problem
check to see if u actually soldered/tapped the correct wires. also check the HU's functions and see if ur front speaker is turned on.
Re: Speaker Problem
Double checked all my connections. re crimped my wires. on both my brothers car and mine. i can also turn all the power to the one speaker (FL) and no sound comes out at all.
Re: Speaker Problem
thats so weird. if you put the old deck back in, does it work again? whats the new deck, sony? did you press the RESET button on the face of the new deck? usually behind the faceplate you push in with a pen. must be reset after a new install or strange things happen.
Re: Speaker Problem
Took the speaker out and put it on the right side and the speaker works fine. so i know the speaker is good.
Re: Speaker Problem
Well i tried the reset button, nothing changed, same problem. Any other ideas? my brother replaced his HU with a new one, same model and same thing happened. If it helps, the model number is KDC-HD942U, from kenwood. not sure if there are any serious kenwood guys on here or not.
Im a Senior Member. Take that Noobs!!
Re: Speaker Problem
k not sure if this helps. girl got me the KDC-MP642U for our anniversary basically yours minus the HD tuner. After the install i noticed the rear left speaker wasn't workin checked everything and after about 45 mins of head scratchin and beind pissed i said f it. i unplugged the speaker for reasons i dont remember and then about a week ago i plugged it in and it works all of a sudden. No clue why but it does. I would say just give it time and itll work or if you wanna make absolute sure you didn't f up wiring pull the deck out and just wire the speaker directly to the front left wires
dbagaus
Jun 10, 2015 09:29 AM
SLeePeR012
Jan 7, 2002 12:24 AM
guy
Jan 6, 2002 04:39 PM
djaber
Jan 4, 2002 06:23 PM
PimpBot5000
Nov 26, 2001 07:15 PM
