Amp ground points?
Old Apr 18, 2004
MegaHurtz's Avatar
MegaHurtz has much to be proud ofMegaHurtz has much to be proud ofMegaHurtz has much to be proud ofMegaHurtz has much to be proud ofMegaHurtz has much to be proud ofMegaHurtz has much to be proud ofMegaHurtz has much to be proud ofMegaHurtz has much to be proud ofMegaHurtz has much to be proud ofMegaHurtz has much to be proud ofMegaHurtz has much to be proud of
Amp ground points?
Are there any spots in my trunk that I can easily ground my amp to?
I don't really want to have to drill more holes than I have to, so if there is a nice place from the factory, I'd like to know about it.
I have 2 units that need to be grounded, my amp and my cap.
Old Apr 18, 2004
civicstyle82's Avatar
civicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to allcivicstyle82 is a name known to all
Where is it mounted?
I had my ground on a bolt near the taillights
Old Apr 18, 2004
MegaHurtz's Avatar
Either on the left or right side my trunk (not sure where it will go yet), but probably the left. As close to the rear seats as possible. Definitely closer to the rear seat than to the taillights.
Old Apr 18, 2004
I guess anything is possible with the right length of ground wire.
Old Apr 18, 2004
MegaHurtz's Avatar
Of course, but as you know the limit on length for a ground wire should be 36"
Old Apr 18, 2004
tfnaaf's Avatar
BLDNPSI Mod
i used the upper strut mounting, just make sure to clean it to bare metal and the shorter the better
Old Apr 18, 2004
MegaHurtz's Avatar
Where is that located? Pics?
Old Apr 18, 2004
custom2k1's Avatar
custom2k1 is an unknown quantity at this point
It doesnt matter how long your ground cable is as long as you have the proper gauge for the length that you are using. The older PPI power class amps told you to have a ground run directly to the battery and to the chassis. My ground is to my seatbelt bolt and I've never had any problems.
Old Apr 19, 2004
MegaHurtz's Avatar
It is a theory and a rule of thumb that grounds should be <= 36".
How this was derived I do not know but should I find out, I will post it
Old Apr 19, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
If you remove the jack access cover (plastic piece at rear of trunk) there will be a grounding bolt behind it. There should be about 6-10 wires already grounded there. The screw should be green. If you don't want to ground it there, find a bolt somewhere in the trunk, or do like I did, and find a place that's near where you're going to mount the amp and cap, get a piece of sand paper, a stripping bit in a drill, anything really, scrape off/sand off the paint to bare metal, and run a self tapping metal screw in it, and ground there.
Old Apr 19, 2004
gizcivic's Avatar
gizcivic is an unknown quantity at this point
i grounding mine to one of the two bolts that hold the trunk lach to lock the trunk NO PROBLEMS
Old Apr 19, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
if you pull up your rear seat you will notice unpainted metal - I used one of the seat belt bolts. All grounds consolidated to a distribution block accordingly.
Old Apr 19, 2004
phuviano's Avatar
Slowest 7thgen in the GTA
I bolted mine to the one bolt that hold down your rear seats. I was testing out all the grounding points in the trunk, and found out that most of the metal of the trunk, willing not ground. All the bolts you see will ground (goldish colour bolts).
If you got a volt meter try it out. Get your remote wire and connect that to your positive terminal on your volt meter, and then keep touching suitable grounding points with the negative terminal.
Well that's what I did at least.
Old Apr 20, 2004
Mystic3030's Avatar
Yup, i'm an A$$hole.
Mystic3030 has a spectacular aura aboutMystic3030 has a spectacular aura about
The bolt that holds down the rear seat cushion is where I have my amps grounded too...it's a good spot.
Old Apr 20, 2004
phuviano's Avatar
haha... I'm not the only one. I had to use a longer bolt though. The stock bolt was too short. I have a grounding block connected to my ground wire, and that's why it would not fit.
I could have just bought a connector, but I was too lazy to go to the stereo shop.
Old Apr 20, 2004
MegaHurtz's Avatar
Hmm something just popped into my mind that I never considered before... If I put my ground under carpet and have carpet touching the ground bolt, terminals, or in the event that wire becomes exposed, is there a potential for a major fiery problem here?
Old Apr 20, 2004
Mystic3030's Avatar
No, you'll be fine, sparks wont happen unless the ground fully disconnects from the metal and then reconnects.
roverben
Jan 21, 2019 05:16 PM
Switch BL4D3
23
Apr 24, 2015 06:57 PM
Trav_02civic
Engine start problems
Apr 23, 2015 08:57 AM
McD
Apr 22, 2015 05:28 PM
