Cabin Filters
take off glove box (one rubber holder on each side that you pop out) and then it will fold down. then you can take off that black piece and pull out each filter. one comes out and then the other slides and comes out.
Originally Posted by Eclectic
so you're saying you can clean an air filter but not a cabin filter?
The only filters that can be cleaned are filters that are replaced and designed to be cleaned, and the cleaning often involves putting oil back onto the filter. As far as I know, there are no cabin filters that are ment to be cleaned.
Mine were worse then that. I don't think they'd been changed ever. 87,000 miles...There were piles of dirt and leaves and other crap...Man what a difference it made.
i changed my bros rsx filters a couple days ago after 3 yrs there was so much dirt it started its own layer of leaves and stuff on tyop of the filter. ya his air was barely blowing before lol.
Originally Posted by Storm897
Dust and Pollen Filter Replacement (With Air Conditioning)
NOTE: LHD type is shown, RHD type is symmetrical.
The dust and pollen filters should be replaced every 48,000 km (30,000 miles) or 24 months whichever comes first. Replace the filters more often if the air flow is less than usual.
1.) Open the glove box.
2.) While holding the glove box (A), remove the glove box stop (B) on each side.
3.) Hang the glove box down.
4.) Remove the filter lid (A) from the blower unit, then pull out the first dust and pollen filter (B). Slide the second filter to the left and pull it out.
5.) Remove the filter (A) from the housing (B) and replace the filter.
6.) Install the filters in the reverse order of removal.
I went to Advanced Autoparts and got 2 replacement filters for 27 after tax. These are Purolator brand and it comes in a 2 pack(so they are around 13 each.) On the box it says "You should replace your cabin air filter every year OR every 12,000 to 14,000 miles"....
Eek I've never replaced my filter and I doubt the previous owners did either!
i clean mine every 10k, or buy new. they get filled pretty quick. i dont remember paying more than 25 for both and i get quality napa gold.
I did my filters today. I didn't believe all the crap I found in it. 3 dead spiders, 6 busted acorns a bunch of those helicopter seeds... And enough dust to make a gaggle of dust bunnies.
Damn just went to Advance Auto price there....25 bucks for the 2 filters
Autozone price there.....25 bucks for the 2 filters
This is in my area in Michigan...
I need to check Napa when I get outta work and ill post an update when I find out.
I think Honda recommends replacing the filters every 30k. More often if you live in the city. $25 every 30k isn't really all that bad. Youll probably spend $5 on gas driving around trying to find a lower price.
