major problem
Old Mar 23, 2005
deciuss's Avatar
Boosted Auto
major problem
ok took the car to the shop finaly hooked up gauges, air/fuel tranny oil temp and psi gauge. well first of all the air/fuel and oil temp dont work so im going to need to buy a new one but here is the major problem.
when ever the car shows one psi now it goes limp basicly i cant acelerate unless i floor it and get it past that point, it does it early 40s, 50s and at 65. also i noticed when i got it back that when i put the car into drive or reverse it takes at least 3 seconds to actualy shift into that now (my car is an auto).
an interesting thing is the car worked fine for 5 minits or so and during that time it only showed as much as 2 psi so i guess thats what i have been running the whole time sigh.
any ideas whats wrong? tranny fuel pump? o ya im trowing 2 coes 131 (02 sencer) 113 (some air sencer high input thing)
Old Mar 23, 2005
djmota's Avatar
Does your sf kit have a check valve or missing link for your map. It sounds like your map sensor is reading boost which is not good.
Old Mar 23, 2005
deciuss's Avatar
Boosted Auto
no missing link or any thing like that, but why would it all of a sudden see it after having the kit on for 5 months?
Old Mar 23, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
no missing link = no boost driveabilty
Old Mar 23, 2005
deciuss's Avatar
Boosted Auto
i know that but why has my car been fine since november but all of a sudden yesterday it has stoped working?
i will tell them to put a missing link on but im just stumped as to why it would do this now
Old Mar 23, 2005
HyaBoosta's Avatar
yeah try the missing link. As for the delay for reverse, my frieind had that in his auto civic right before the tranny gave out. It take 3 sec now but as time goes on it's going to take lopnger and longer to shift into reverse. Get some funds ready for a spare tranny incase. It's only a matter of time. you might want to invest is a tranny cooler. The o2 codes. Do you have a high flow cat? Because the first code is when the secondary sensor is reading the same as the first. and the high voltage is for the primary sensor which means that your car is running richer then it should.
Old Mar 23, 2005
2K1Civic17"Gabe's Avatar
are all your settings the same? It sounds like it could be lean too, check to make sure everything is saved still. Could also be the MAP sensor. I dont know how it handled the boost this long. Get possibly a new MAP sensor, and a missing link. You do need one for sure, or your map will get f'ed. You dont want the ECU to see boost.
Old Mar 23, 2005
teampointless's Avatar
Ultimate Member
I have a tranny cooler that was from dezod's turbo'd auto if you need it. $50 shipped.
Old Mar 23, 2005
I was throwing that 113 code the other day. What it was, is that when we installed the kit, we were unsure if the wires were backwards, so we tried them the opposite way, adn the car wouldnt start, so we did a "quick" solder to it, and it came somewhat loose. It was throwing that code. High voltage to sensor type thing. Get the missing link. My car bogs down (feels like it, it could be from going to boost to stock) for like half a sec when I shift, than picks up. Is that normal boost lag? and should it go lean in that time?
Old Mar 23, 2005
deciuss's Avatar
Boosted Auto
i allready have a tranny cooler and have had one for over a year before the turbo.
ok problem seems to have been the crapy check valve that sf had come with the kit shop orderd a missing link so problem should be solved thats the update.
Old Mar 24, 2005
civic01vtec's Avatar
lol........i never even installed that POS check valve.........i bought a ML from the start
Old Mar 26, 2005
deciuss's Avatar
Boosted Auto
lol new updata it was better but still doing it with the new ML an o2 sencer is bad not the one on the cat but the other one. cars been running rich and that killed the sencer i guess no car untill next week 3 sencers replaced so far i could have got the emanage and have it tuned perfect for the cost of replaceing all that junk
Jon-Ohio
Jun 30, 2018 08:10 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
lapchern
Bolt-on Engine Performance
Dec 22, 2001 06:23 PM
