pressure problem?
Old Jan 18, 2005
deciuss's Avatar
Boosted Auto
pressure problem?
i have the upgraded sf turbo on an auto civic. from every thing that i have seen/read fwd should be best at a roll but with my civic i cant seem to build boost past 25 mph.
if i floor it from a stop (example going onto a expressway) i have full power all the way untill i get to 70 (when i take my foot off due to im at my crusing speed).
i know a bigger turbo takes longer to spool but i should have some hp from a roll right?
Old Jan 18, 2005
Nick's Avatar
Formerly 2blu
Maby You have a vaccum leak somewhere? Or a broken wastegate?
Old Jan 18, 2005
deciuss's Avatar
Boosted Auto
if i had a leak wouldent it be there the whole time from a stop or a roll? i will chex into the broken wastgate thing
Old Jan 18, 2005
EternalBlue_Vic's Avatar
Boosting Daily
EternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the roughEternalBlue_Vic is a jewel in the rough
How is your idle? Smooth, rough? If you have a vaccum leak, your idle will be killer. Check all your couplings. You may not have a vac leak, but a boost leak. I was entering the highway one night WOT at full boost then KUNK!...0psi....not boost...nor could i build any. I pulled over in a gas station and checked the probem. The pressure had blown the downdraft coupling off of my throttle body. All i had to do was re-attach it and tighen the clamp firmer. Maybe you just have a mild boost leak somewhere from the compressor->intercooler->throttle body.
Old Jan 18, 2005
Boosting Daily
Double check your vaccum connection from the compressor to the wastegate. Internal, right? I strongly doubt its a broken wastegate though. Mostly when a wastegate goes, you'll build insane amounts of boost because the gate isn't opening.
Old Jan 18, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
That sound like a boost leak. vaccum leaks ur rpm would be jumping up and down like crazy. If you have a boost & vac gauage. On idle the vac should read @ 20.
Old Jan 18, 2005
Nick's Avatar
Formerly 2blu
oops i was wrong. don't listen to me.
Old Jan 18, 2005
civic01vtec's Avatar
i don't understand what you mean..........are u saying that you if you floor it u build boost, but once you hit 25mph u loose all boost
Old Jan 18, 2005
happened to me too.......pipe blew right off of the TB......... hairspray is a wonderful thing
Old Jan 18, 2005
Boosting Daily
I idle @ -22mmhg
Old Jan 18, 2005
deciuss's Avatar
Boosted Auto
no if i try to accelereate fast from a roll over 25 most of the time i have no hp gain other then stock.
my car is a little more ruff then it used to be but nothing to bad at idle
Old Jan 19, 2005
Boosting Daily
do ya have a boost gauge? If you do, check to see if you're building boost. If not, then it's def. a boost leak. If you're building peak boost, then you might be running extremely lean. My ICU re-setted for no friggin reason last night and went down to my extra injectors only spraying 0.4Ms in every boost setting, when they were normally running 9+Ms @ 1psi, 10+Ms @ 2psi, 12+Ms @ 3psi, etc, and up. It ran so lean the car ran worse at 6psi then it did at 2psi. Do you have an a/f ratio? If not, best to get one, as CrewChief so bluntly put it, "Don't go pissing in the dark!"
dinsum
May 28, 2015 09:30 PM
usajags84
May 10, 2015 08:11 AM
delacampos
Transmission
Jan 2, 2002 02:06 PM
2k1USMCivic
Jan 1, 2002 01:24 PM
CiViCPrAnInG2k1
Nov 1, 2001 03:47 PM
