DIY: Converting primary o2 sensor from narrow to wide band for KPRO USE ONLY
Old Jan 20, 2009
skipbarber's Avatar
So a while back Boilermaker posted My car got an IQ boost..... In it you will find that I converted his stock narrowband primary o2 sensor to a stock 04-05 wideband setup so that the Kpro can pick up AFR readings more accurately and take advantage of the PRB calibrations the Kpro is capable of. I wont go into much more detail because it starts to sound really nerdy and I also know that very few people are going to do this conversion, and if you do it, you already know the advantages of it. so here we go.
Supplies you will need:
-an automotive SPST or SPDT 12v 30a standard relay. preferably one that comes with a socket, otherwise spade terminals and a crimp tool work just fine.
-you'll need a few feet of wire, 16AWG.
-3 OEM ecu pins. You need to add wiring to the oem connectors. My dealer looked at me like i was crazy when i asked for this, so i bought an entire harness on ebay and gutted it for connectors and pins. This is where I got my vtec connectors from
-zip ties.
-a wire fishing tool or clothes hanger to run your wires through the large firewall grommet.
-soldering iron and solder.
-electrical tape.
-an AFR sensor from honda for a 04-05 D17 civic. this is the only one we know works for sure, it's likely other blue plugged honda AFR sensors will work with the Kpro calibration, but it's a gamble.
-about an hour of time.
-a new kpro map for your setup.
Procedure: 3 pins are being added to your ECU, a relay is being added to the circuit and a sensor is being replaced, obviously.
The first step is to drop your glove box and get to your ECU. I prepared my wiring on the bench, outside of the car. it's a fairly simple circuit.
You can use a honda relay if you want, but a generic radio shack relay works fine. I labeled the diagram for both. If you're using a SPST relay, you have 4 pins, if you have a SPDT relay you have 5. Either way you only need to use 4 pins, if you get a SPDT relay, just terminate pin #87a.
pin 85: connect this to the thinner of two black with white stripe wires in the wide grey plug near the ECU.
pin 84: connect this to pin E8 in the ECU.
pin 30: goes to a constant 12v source such as the ignition harness
pin 87: goes out to the sensor.
inserting pins is fairly simple. it's easier to show on the grey plug. youll notice it has a wide white insert, using a pick or small screw driver pry it up a little. you cant pull it all the way out.
ignition tapped here for the relay. be sure to solder and tape this connection.
finally, there are two wires you will snip out of the factory o2 connector, and where you will add the two you just ran out to it. you will also need to change the gender of this plug, if you cant get a connector, you can hardwire the o2 sensor. I used some snazzy heat deflecting loom to mine and extended my wires since my primary AFR sensor is no where near the stock location. If anyone is interested I can make a few "kits" that include everything you need for this conversion and have it prewired and labeled so you can simply run and plug in your wires. Anyways, once youve done this your car has officially been converted to 04-05 o2 sensor layout. now you simply follow the directions on hondatas website to enable the secondary o2 sensor, which just requires you to move 2 pins. Moving them is just as easy as putting them in, once the lock is lifted out you can gently tug on the pins to get them out of the connector.
Im going to update this thread when i feel like typing more. do this at your own risk. My first impressions are....damn. i cant believe i drove my car without this for as long as i did. the difference is night and day and having the AFR datalogged with everything else makes tuning a hell of a lot easier. have fun.
Old Jan 20, 2009
supafil25's Avatar
supafil25 will become famous soon enough
Re: DIY: Converting primary o2 sensor from narrow to wide band for KPRO USE ONLY
how much for a kit?
Old Jan 21, 2009
civicsrcool's Avatar
civicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond reputecivicsrcool has a reputation beyond repute
^^ uhhh. its not a kit. lol. he is simply telling you how to do the conversion.
awesome post BTW. should be stickied and maybe should be posted on k20.org!
Old Jan 21, 2009
skipbarber's Avatar
Originally Posted by supafil25
how much for a kit?
im thinking like $20+ shipping , since all im really doing is providing ecu pins and a relay pre-setup and there is still some wiring the end user will have to do. the new AFR sensor would not be included, obviously, but if there is enough interest i can probably get some at a discounted rate.
Old Jan 21, 2009
skipbarber's Avatar
i mentioned in the DIY that i could make a kit if there was enough interest.
Old Jan 21, 2009
oh damn reading > me. doing it big huh!
Old Jan 21, 2009
bomerman19's Avatar
bomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond reputebomerman19 has a reputation beyond repute
Nice edwin! +1 good stuff i might hit you up for one of those kits if I'm feeling lazy lol
Old Jan 21, 2009
speedfoos's Avatar
Bookmarked for later. Good stuff Edwin.
Old Jan 21, 2009
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
good thing i already have an 04
Old Jan 21, 2009
TRIZ's Avatar
Good stuff- I was trying to figure this out on my own a while back. Glad to see you got it all figured out. =) Thanks, stickied!
Old Jun 18, 2009
greeen01civic4d's Avatar
bookmarked, i may end up pming u at somepoint if this doesntgo as planned
Old Jun 20, 2009
alright, performed said actions, any idea why i have 02 heater circuit malfunction code? p1166(yes i know it can be disabled, but i dont want to burn out sensor)
Old Jun 21, 2009
skipbarber's Avatar
where did you tap your constant 12 volt source for your relay?
Old Jun 27, 2009
supafil25's Avatar
whats your paypal? i want to buy a kit, and the sensor i just get one for an 04-05 civic?
Old Jun 27, 2009
i tapped the constant into the radio power harness
Old Jul 9, 2009
skipbarber's Avatar
does the relay click on when you turn the ignition on?
Old Jul 9, 2009
u know thats a damn good question, ill have to look into that. for now im tuned so its not as important, but id still like it to work
Old Jul 9, 2009
Boilermaker1's Avatar
Jap-Euro Fusion
I'm pretty sure when I got mine I bought the sensor from an 04 LX, but it shouldnt matter. Make sure you buy the "Air Fuel Sensor" It should be around $110. Id you look at the parts schematic its the one before the cat. You could get one for an EX, or even one for a K20, anything should work with Kpro since they're all outputting the same values...
Old Jul 10, 2009
bomerman19's Avatar
were did you get your sensor justin I'm having trouble finding any for less the $195
and adam I thought it was working on your car
Old Jul 11, 2009
it was working, but the heater failed, so bye bye sensor.... and go to rockauto or something, they have one, ill get u a part number on monday when i get home, i have the box at home
Old Jul 31, 2009
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
Can this conversion work on a PRA - ecu that is normaly using 2 narrowband
sensors?
Old Jul 31, 2009
skipbarber's Avatar
This conversion DIY was made for D17's originally running with just 2 narrow band o2's. As long as you do this, and load the correct calibration, you should be fine. I've discovered that loading the correct calibration is KEY, otherwise you can run into problems. I didn't have to disable any codes to get this setup to work correctly on two different civic's. So if you come up with a code, check your wiring, ensure relay functionality and double check that you have the correct calibration loaded onto the Kpro.
Old Jul 31, 2009
bomerman19's Avatar
hey edwin I just got the wideband sensor in the mail yesterday I'm about to try to wire it up this weekend
Old Jul 25, 2022
whelan190's Avatar
whelan190 is an unknown quantity at this point
hi i have an 04 uk spec ep3 with a kpro and standard o2 sensors can i do this mod to my car and use my sensor or do i have to replace the sensor?
Old Jul 25, 2022
thread is 13 years old.
EP3 have a K series engine
this thread is about the D-series engined civics.
so, you are asking in the wrong thread, unsure what you are asking. for D series engines, Narrow band is used on 01-02 civics, 03-05 are wide band.No idea for US EP3, much less UK EP3
a 5 min google indicates the EP3 uses wideband primary o2, 2nd is narrow
why do you think the sensor is narrowband?
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
rileysowner
Feb 12, 2023 07:52 PM
dabatman99
Jan 23, 2016 01:19 AM
andyman97
Engine Swaps
69
Mar 10, 2008 12:56 PM
wikkaco0
Engine Swaps
23
Jun 27, 2007 05:07 PM
