How I solved my dash rattling..
Well solved most of it anyway. My dash rattle was really getting out of control. I also was experiencing some clunks on bumps and when brakes were applied mostly from the front of the car. These have gotten gradually more noticeable over the last 3 months. I replaced the stock front lower control arms, stock front end links, and stock ball joints. (Also put new rotors on the front). This was my first attempt at control arms ball joints etc. It was fairly easy once I got the right ball joint press. Some stores carry a press whose metal sleeves are just a millimeter too wide to allow for the receiving sleeve to fit over the ball joint and not push against the knuckle. All that said the car drives really good now, no clunks and.... the dash rattle is virtually non-existent.
Prelude Owner
Re: How I solved my dash rattling..
glad you figured it out. That can get annoying.
I think the last time I rented the ball joint tool I had to get a special "Honda" kit to go with it.
GOT SAND?
Rep Power: 0 Re: How I solved my dash rattling..
I just did both lower control arms, stabilizer end links, ball joints, and inner/outer tie rod ends. Didn't have the dash rattle though. Car does ride better, and the steering is a bit tighter then before for sure. There is a special ball joint tool for Hondas, and for what it's worth, there's a Honda inner tie rod tool as well. Found that out the hard way. For the life of me, I can't figure out why Honda designed the lower control arms the way they did. They should pivot in an up & down motion like most A-arms do.
ishmot
01-02-2016 09:53 AM
steve6
11-22-2015 08:18 PM
