Mechanic Told to replace LCA Bushings and Lower Ball joints
#31
Received 1,127 Likes
Rep Power: 191 Re: Mechanic Told to replace LCA Bushings and Lower Ball joints
I used beck arnley ball joints on my old car and they seemed like a good quality part, I also liked the fact that they were non-greaseable (I hate grease fittings)
#32
For the buyer that means that you could get an OEM or an aftermarket part. I purchased two BA front lower control arms (ball joints included) for a Mazda 3 and the parts looked exactly like the original part and worked without issue for three years..until car was totalled.
#33
#34
From what I've read Beck Arnley buys up overstocked parts and rebrands them to their own label. One (of many) link(s): https://forum.ih8mud.com/threads/bec...-to-oem.52404/
Well, guess I'll be experimental and will find out
#35
Can anyone advice if this(or similar) procedure can be used on LCA's compliance bushings? Though, I have already ordered LCA's but instead of installing cheap chinese one, I might just install the compliance bushing and keep those 'new' ones as a back up?
https://www.youtube.com/watch?v=aPbL...ature=youtu.be
Can anyone please chime in and provide some help? Thank you
#36
Just to close the loop here, did this work this weekend. Almost everything was easy and straight forward, except few suggestions which I would like to add:
1- Stabilizer end links can be a royal PITA because of rust, had to cut when I was doing the first one. Second one went smoothly.
2- Rental tools for popping old ball joint(used an impact it was super helpful), as well as press for new ball joint can do wonders and be very helpful.
3-One of the axle bolt was all rusted, it was a royal PAIN to remove it.
Second side went very smoothly and quickly, so take your time while doing it and do a lot of research and reading. Removing and pressing ball joint is the only difficult part.
I would stay away from Moog R series LCA's. Bushings on them look too cheap.
Good luck and let me know if any questions. Thanks to everyone for their input and help
maverickfhs
01-02-2017 08:23 PM
