power window blows fuse 22
Old 10-16-2016
jewlzmarie's Avatar
jewlzmarie is an unknown quantity at this point
what should i do? power windows all work on main and individual switches except front passenger window, blows fuse #22 every time!! bought new motor,switch, regulator. and still blowing fuse 22! whats the deal and how can i fix it? PLEASE ANY HELP IS BETTER THAN NONE AT ALL!
Old 10-16-2016
Re: power window blows fuse 22
Post moved to make a new thread.
What year is your car?
Is it a sedan (4 door)?
You install a fuse and you only say it is still blowing every time. Need more specific info:
What do you have to do exactly to make the fuse blow?
Which window switches did you replace, and did you buy brand new switches?
Old 10-17-2016
jewlz40's Avatar
jewlz40 is an unknown quantity at this point
turn on car it blows, 2001 honda civic ex,trying to replace broken glass but cant lower regulator to do so, passenger side front on 4 door
Old 10-17-2016
jewlz40's Avatar
Re: 01 Rear Passenger Power Window
can i lower a power regulator manually to replace broken glass on a civic 01 ex sedan? no power will fix when i can afford but just ned window in now.
Old 10-17-2016
jewlz40's Avatar
llll
Old 10-17-2016
jewlz40's Avatar
tested switch not it . on 2001 honda civic ex sedan, something keeps blowing the fuse 22, when car is turned on, have new reg and motor, glass window, and new/used switch tested works. now dash lights for speedometer and fuel gage lights are out! wat the heck???
Old 10-17-2016
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
You may have a short in the wiring harness in the passenger door. Check behind the rubber door conduit for pinched wires first then work your way from the pass door switch to the fuse 22.
Old 10-17-2016
CraigW's Avatar
Good candidate for one of those fuses with the LED inside that lights when it is open.
Leave it in place until you locate the short.
Old 10-17-2016
I'd guess wiring in the drivers door jamb broken causing a short circuit and blowing the fuse...
To lower the problem window regulator, remove door panel then unplug the window motor and use car battery with small jumper wires to connect to the window motor and make it run.
Dale Irish
05-12-2016 12:53 PM
Hutch1051
04-24-2016 01:13 AM
RIPSAW
04-24-2016 12:32 AM
Jack_Maehoffer
04-02-2016 04:41 PM
jksdaddy22
03-19-2016 10:26 AM
Quick Reply: power window blows fuse 22
