Exhaust rattle, but don't think it is heat shields-need help finding issue
Hello everyone,
I spent considerable time searching this and other forums and on google. I found many articles stating they had rattling from the exhaust, but many were the heat shields. I have an 05 Civic sedan LX Special Edition auto and I'm getting an exhaust rattle where the converter meets the first part of the exhaust pipe underneath the car.
I can get the rattling when the condenser and radiator fans are on (with the AC running, or without the AC when the car is hot and need the fans to cool). I also get the rattling when I'm idle in traffic, especially if I'm turning my wheel slightly (don't know why, but I guess it's because the engine/transmission is working harder at that specific moment).
I confirmed the exact place where the rattling is by jacking my car up and I had my GF turn on the the AC (to get the fans running), and I held the exhaust pipe at the location where the converter meets that first exhaust pipe (see pics below and red circles of where I'm talking about). Any idea what could cause rattling at that specific location?
I tried seeing if any bolts were loose, but they are tight, as well as rusty. The bolts around the converter are rusty too, so I didn't want to try and tighten them and one break off.
Any advise what else to check for? I don't think it's the heat shield, so my thinking is, could it be any mouns or something else adjacent to that specific spot making the exhaust bang against something else? No new work or anything has been done to the car, except a regular oil change I did 2 weeks ago. The sound has been going on for a while, but every time I heard it while in my car, I thought it was someone else's car making that rattle. Everything is stock on the car.
Thanks in advance.
Thanks in advance.
Re: Exhaust rattle, but don't think it is heat shields-need help finding issue
High mileage, maybe 180k-250k? Rattle sounds like something much heavier than the flimsy tin heat shields?
I'd suspect the Catalytic converter......the substrate (guts) came loose from the steel shell, the rattle noise is coming from inside.
Dr Krieger of Modification
Grab the cat heat shield at each corner and try to pull it apart.
Sometimes they look like they are bolted together but the bolts/rivets rusted through.
It could also be the cat plate inside the cat. but that would through a code... do you have any CELs on?
You could also drive through an oil shop and ask for them to check it out.
Most good shops will do visual checks free in order to maintain good business.
What is involved with fixing the substrate/guts? Is this something a DIYer can do (with typical at home mechanic tools--with some extra power tool) or is this something I would need to take to a shop?
Thanks.
Thanks.
120K on the odometer. It actually sounds like a light rattle. I couldn't hear it strongly for a couple months to think it was my car, but its not a heavy rattle.
Thanks.
Thanks.
How about using a rubber mallet to tap on the exhaust while you search for the noise? Surely that could make it rattle if it is exhaust or shield related
The following users liked this post:
Andym (09-08-2021)
Now, one thing I can think of. The bolts that join the converter and exhaust pipe are pretty well rusted. It could be a breakdown in the connection because of the rust, making the connection looser causing a rattle (I tried tightening the bolts I could access, but they were already very tight), or it could be part number 8--the rubber mount that holds the exhaust pipe.
When the AC was on (or fans running to cool the car) the excessive vibrations cause the rattle. When I was under the car and AC on, I held the rubber mount and it stopped the vibrations. The rubber mount didn't look overly worn, but I don't know how tight/firm it is supposed to be. The rubber was flexible, but still slightly firm.
The other thought that just came to me, is could there be any worn motor mounts or anything that is allowing the engine/transmission to have excessive vibrations when the AC is on?
Other than that, I am at an impasse.
Thanks.
Andym (09-08-2021)
The rubber hangers...If not torn they are usually fine. They must allow the pipes to move around as the drivetrain moves.
How about (in the first parts diagram) bracket #1 and the two bolts #10, it is supposed to anchor the bottom half of the cat to the block......
Get it making noise, wedge a prybar to apply pressure or move the bracket, and see if noise stops?
In the second parts diagram you made a circle on the front end of cat assembly #4, but since you have an LX I think you really have pipe #11 in the car. No biggie.
The flex-joint (bolts with springs) between the bottom of the cat and the first pipe, is the cone shaped gasket (donut) worn and allowing metallic contact between the cat and first pipe? I've heard some make a rapid squeaking noise as the engine vibrates.
Andym (09-08-2021)
Engine off, flat ground, shifter in park, handbrake off....rock the car back and forth see if the pipes make noise as the engine/trans rock against the park stop?
Would this be an easy fix, meaning, is it simple to take apart to check (if I cannot eyeball it), then put back together (to confirm the gasket is the issue)? Or, should I only take it apart with the expectation to replace the gasket. I also won't have a lot of clearance under the car, so I'm not sure how those flex-joints are installed, or if I'll need a long torque wrench for anything. I'll only have the space under the car after the car is jacked up (and on stands), so if I take this apart, can the exhaust pipe hang without being damaged?
Thanks.
o I have to take this off to check, or can I eyeball it. It's tight under there with no lift, so checking this could be a challenge.
I'd expect to replace the donut gasket if it comes apart, and depending on condition maybe have new bolts and springs ready ahead of time in case they break, or round off...You know, have a backup plan if it has to come apart and goes sour.
How about using a length of tubing or hose held tight to your ear as a sort of stethoscope?
Get it making noise... Move the free end around to find where the noise is loudest
the bigger issue might be 'can it be taken apart without breaking anything?'
Thanks.
I don't know torque specs, buy if anyone has them or know where I can find them, please let me know.
16 ft lb sounds like a number used for 8mm hardware....(did not look, I've never put a torque wrench on one of these)
The bolts will screw in and bottom out on a flange.
The springs keep the flex joint pushed together and allow it to move.
I did another check today, and I was not able to replicate the rattle. It could be because every time I heard the rattle, I drove the car for a little while (like from work to home which is about 15 miles for me) and today I did not have to leave the house (as of yet).
I had a prybar with me and I was able to move the bracket slightly (like a couple millimeters), but since it was not rattling, I was not able to see if this was the issue.
I also got underneath today to see if I could eyeball the condition where the gasket goes and to confirm the bolt/nut (flange) count for if I were to replace the gasket (online listed I need 4, so this confused me, but I think 4 was for both the front and back of the exhaust pipe). I confirmed I only see two each of bolts, nuts, and springs, so that plus the gasket would only cost my like $65.00 locally from the dealer.
My new question is this, do these gaskets wear down, or is it typical wear for a car at the ~120K mile mark?
Also (and just making sure), if I were to attempt this repair, would removing the two bolts, springs and nuts be enough clearance to get the old gasket out and new gasket in, then put everything back together, or is this one of those repairs where I would have to drop the entire exhaust pipe to give me enough space?
I am okay with buying the parts and doing the replacement since I can't really pinpoint the exact problem, but it's nice that we've narrowed it down to a couple of possibilities.
Thanks.
Thanks.
There should not be separate nuts, they thread into the flange on the cat.
I only tossed the idea out because I've seen it. IDK if it's actually your issue or not, that's for you to decide.
Your question helped solve my issue (hopefully). The upper bolt was loose enough to turn by hand. I was able to tighten it with my ratcheting 14mm wrench and voila, hopefully problem solved.
I'll be going out tomorrow so I'll be able to test this after riding in the car for a little while. I'm glad I didn't go through all of that extra repair/replacement for nothing. I'm confident this is/was my issue. The looseness of the bolt was probably making the bottom of the coverter rattle against the frame.
Thanks a million, Ezone. Much appreciated for all of the help you provided.
Andym (09-08-2021)
Fingers crossed
Andym (09-08-2021)
Andym (09-08-2021)
thank you for this.
I have had this issue since last year when someone replaced the transmission and I ended having to replace the 2 springs and 2 bolts holding it because one of the bolts was completely bent but the issue continues. Surprisingly i found it was missing bolt number 10 later and i said that's it finally but no, the Problem continues and it's right there. Tomorrow I will check every single item and take everything out and check that gasket too.
I have purchased all sorts of things trying to make it vibrate less and nothing made a difference into the muffler issue
4 New denso ignition coils, replaced again the transmission mount this time with a better quality one that comes with the weight balance in it and nothing.
Ordered 4 oem restored fuel injectors for $116 on ebay and waiting to install it tomorrow and hoping it will make a difference in fuel economy and else and again bought the PCV valve this time OEM because the beck arnley ones make an incredibly anoying noise.
Also purchased a power steering pump for the 4th time and hoping it will work fine. The other thing and thanks to this topic, i almost bought the idle air valve thinking my idle is getting low causing the muffler vibration when the A/C goes on and after the car is warm up enough.
Received 1,443 Likes
Rep Power: 338 Re: Exhaust rattle, but don't think it is heat shields-need help finding issue
have someone to check your chassis for cracks? (what i have seen was not in a civic, but possible)
Actually the noise is right there in the muffler and exhaust union where the bolts connect, I shake it with my hands before and it made the metal clanging noise. I believe the guy who mounted the transmision never installed the bolt number 10 and it might had caused other problems along the time because of that and i even also hear a loose piece of something from else where when i accelerate hard since the begining on the transmission transplant. I regret not doing the transmission switch myself at that time.
fvckbg
07-07-2015 07:08 PM
LividHatred
06-20-2012 03:35 PM
vinothm
06-09-2008 04:29 PM
civic02ex
10-03-2003 11:01 PM
