Difference Between Vtec and Non-Vetec Manual Trans
Received 1,126 Likes
Rep Power: 191 Difference Between Vtec and Non-Vetec Manual Trans
Hey guys,
So my car (2005 lx sedan) has a bad input shaft bearing.
Last week I bought a used tranny to put in my car. This will give me time to rip apart my old trans, and try to fix the bad bearing while still having the ability to drive my car. (I work six days a week)
The trans that I bought is out of coupe with vtec. So my question is, am I going to have to replace anything to make it work in my car?
I didn't think so at first, but now I'm starting to wonder.
Are the axles the same?
I was planning on putting in a new clutch and having the flywheel machined while I was swapping the trans. From what I can tell It's the same part number from exedy.
The guy I bought the trans from gave me the starter for the trans, so I have the starter, if mine isn't compatible.
Thanks in advance for any input.
Re: Difference Between Vtec and Non-Vetec Manual Trans
Biggest difference I can think of might be the gear ratios.
Otherwise, I'd think it should bolt right on.
Received 1,442 Likes
Rep Power: 338 Re: Difference Between Vtec and Non-Vetec Manual Trans
yeah, the EX is shorter geared. I think the axles were the same, case the same.
Nerd alert!
There's a boatload of axle choices in a Honda parts catalog, different between VTEC and non-VTEC and country of manufacture, in addition to trans type.
Consult an aftermarket parts catalog to see if they show differences?
Rep Power: 191 Re: Difference Between Vtec and Non-Vetec Manual Trans
Thanks for the help guys!
Maybe...
I'm in the US, my factory catalog does not tell what the differences are nor what can interchange. All this gives is different part numbers.
Aftermarket generally consolidates more than factory.
The image is from selecting 05 civic 4 door with a manual trans, selecting an 05 2 door manual trans gives the same options.
So it seems like I'll be ok. Only one way to find out.
Question about the flywheel....
Is it a 'stepped' design? I've been phoning around for machining prices and they all seem to be +$100 and one shop mentioned that it was because it was a 'stepped' flywheel.
If the flywheel isn't damaged and the last clutch did not chatter, I just slap the new clutch parts on and go. My best luck seems to be not touching anything I don't absolutely have to.
That said, the Honda service manual says to not machine the flywheel. If it needs anything then it gets replaced
Ok thanks ezone,
I don't think it's chattering, hard to tell with all the input bearing noise.
The input shaft will probably be damaged when I rip apart the trans, it drives fine though.
Quick question, do I need 12 point sockets for the flywheel and pressure plate?
Hopefully doing this on Sunday.
I really can't remember.....been a long time.
Newer stuff uses 12pt on flywheel bolts so I bet that does too, and pretty sure the pressure plate uses 6pt.
Ok thanks ezone, any chance you'd remember the sizes off the top of your head?
You're asking for an awful lot....I can't remember if I wiped my *** or washed my hands 10 minutes ago....*shakes your hand*
8th gen uses 17mm 12pt on its flex plate. That's about all I remember.
You should always have a variety of the usual Asian car metric sizes, 90% of the car will be using some form of: 8 10 12 14 17 19, plus something for the axle nuts
I have lots of sockets, just not too many of the 12 point variety. So I ordered the 17mm and the 10mm from a place here in town and they should be here tomorrow. (I'm 90% certain I don't have those ones already, and they were $8 each). I have a 32mm for the axle nuts, I think everything else is normal sizes.
Currently I'm getting 7.5L/100km, or 31.36 MPG, so it will be interesting to see what my mileage will be like after the swap. Probably a little lower, but hopefully not too bad.
Got it done yesterday, took a while longer than I expected, buts it drives and shifts way nicer than it did before. Of course I broke the two spring bolts for the exhaust, but that will get fixed today. Haven't taken it out on the highway yet though.
Tedverseti
10-22-2015 01:09 PM
viper775
11-22-2001 10:09 PM
