overheating
Rep Power: 0 overheating
Hi, i have a 2002 Honda Civic lx.My car has overheated 2 times since last wed. First 2 weeks ago I had a new radiator put in and car ran fine. Last wed I was going up the mountains and it overheated. it drove fine threw the rest of the week (to and from) work. Friday night I was driving about 15 min and it overheated again. Noticed the fans werent working. I replaced the thermostat and still overheated. So I jumped the fans with a paper clip and they both went on so I know there both working. I also jumped the relay switch and its working.so then i replaced the cool fan switch and still over heating. I ran the car with heat on for 20 min and fans never came on and it over heated and did the same with the air. Anyone know what else it could be? everythigns working but still overheating. TIA
Re: overheating
I did not see any mention of refilling the radiator. Is it empty?
Head gasket, just because.
Rep Power: 125 Re: overheating
WHEW! --- I was beginning to fret we'd make it a whole day without an overheating post.
Rep Power: 183 Re: overheating
Head gasket is not necessarily the culprit. I would make sure your fans are cycling before taking the head off. If they aren't turning on then that is probably the issue. If the switch relay and fans seem to operate on their own then, I would look at wiring.
After that I would test for a blown head gasket.
He did not mention coolant consumption, if he doesn't have any then that is not the case.
Do water pumps gradually go bad? I thought they just gave out like a light switch, they are directly attached to the belt, so I don't see how it could be weak flow, only flow or no flow... Correct me if I am wrong.
Re: overheating
Could be bearing going bad:
Car Problems & Maintenance : How to Tell if a Car Water Pump Is Bad - YouTube
Also I could not get audio for some strange glitchy reason, so all I saw was the pictures.
Honestly I have never had to deal with this issue, because I replace the pump every time I do the timing belt, it's just insurance.
Re: overheating
Duplicate
where is delete button
please delete this duplicate
pppppppppppppppppppppppppppppppppppppppppppppppppp ppppppppppppppppppppppppppppppppppppppppppppp
llllllllllllllllllllllllllllllllllllllllllllllllll llllllllllllllllllllllleeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeeeee
aaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa aaaaaaaaaaaaaaaa
ssssssssssssssssssssssssssssssssssssssssssssssssss ssssssssssss
eeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eeeeeeeeeee
Re: overheating
^^^Good Gawd that place looks like a hole.
Tires along the ceiling like a gas station, grease stains all over the walls.
Or maybe that's black mold I see?
SOAP AND PAINT ARE CHEAP!!
^^Ditto on the blue RTV, and IMO the same goes for orange RTV.
Both scream 'amateur' in my world.
Re: overheating
I do not trust a man who puts that much blue RTV in a place that needs no RTV at all.
I've had intermittent overheating to an old 1970's Datsun B110 https://www.google.com/search?q=dats...IVTO8UCh1tcQCD I owned about 30 years ago. Replaced water pump and was good to go until I sold it. Rear wheel drive..schweeeet. Only other car that looks as cool is this : https://www.google.com/search?q=rx3&...FYtyFAod5YcFSQ
Maybe I am wrong? Just going by my own experience in which the water pump did cause a low flow situation.
Read it and weep ..son: http://autoresource.internetautoguid...-bad-1389.html
Re: overheating
I've witnessed, diagnosed, and fixed more than I care to remember.
YES it happens --- and for various reasons.
It's not a common problem, but it does happen.
Impeller blade/fin wear
Housing wear
Block wear
Impeller slippage
All can cause low flow problems.
Housing wear
Block wear
Impeller slippage
Re: overheating
Water-pump talk is good an all but, what's really important in this thread is this:
https://s-media-cache-ak0.pinimg.com...a777309b1a.jpg
That's hot & over-heating for ya!
Re: overheating
Yes, Check out the rotary symbol in the front grill.,here's more: http://www.cardomain.com/ride/3825316/1973-mazda-rx-3/
Ezone.. ever work on one of these Honda's: Leno's head is about half the size of the car.
solarpunk70
04-12-2016 11:43 AM
raymondxcho
09-29-2015 09:00 PM
tooly145
09-05-2015 01:05 AM
liagreenhalgh92
07-21-2015 01:31 PM
