Ac belt question.
Rep Power: 0 Ac belt question.
I'm about to remove all a/c components from my 03 civic ex but i noticed that the belt on the ac compressor is shared by atleast the alternator also if not more things. so my question is what would i have to do to remove that ac compressor and still have a belt power the alternator and whatever else is utilizing that belt once the compressor is removed?
EM2ti
Rep Power: 269 Re: Ac belt question.
I believe this is what you would need:
Gates K060338 (34 3/8” or 872MM) Belt or similar
I'm contemplating on doing the same this summer. Good luck.
Rep Power: 0 Re: Ac belt question.
Nothing. The power steering pump is driven off the "smaller wheel" on the crank pulley. The A/C shares a belt with the alternator (off the "bigger wheel"). If you remove the A/C, you would just need to get a smaller belt for the alternator and the crank pulley.
WaryDriver
08-16-2015 11:22 AM
Ray Darvi
08-12-2015 11:55 AM
WaryDriver
08-08-2015 05:08 PM
DerbyDad03
07-27-2015 11:34 AM
1khilari
07-09-2015 08:12 PM
07, 2002, 2003, ac, air, alternator, alternatorac, belt, changeaacbeltonahondacivic, changing, civic, compressor, conditioning, honda, location, run
