Go Back   Honda Civic Forum > Honda Civics by Generation > 7th Gen Honda Civic > Mechanical Problems/Vehicle Issues and Fix-it Forum
Welcome to civicforums.com!
Welcome to civicforums.com.
LinkBack Thread Tools
Old 2 Weeks Ago   #1 (permalink)
MoeGalvez
New Member
MoeGalvez is an unknown quantity at this point
Power Steering Leaking inside the car
Hi everyone, I have a problem with my Civic LX 2002, a few weeks back the power steering fluid is leaking inside the driver side of the car, the carpet is getting ruined and there is fluid in the engine, but I can't find the leak. Any help is going to be greatly appreciated, before the dealer squeezes me.
Thanks
Moe
MoeGalvez is offline   Reply With Quote
Sponsored Links
Old 2 Weeks Ago   #2 (permalink)
gearbox
Super Moderator
gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future gearbox has a brilliant future
Re: Power Steering Leaking inside the car
one of the hi pressure hoses prolly just tore. usually you can get em at the auto store for $30, but you gotta figure out where the leak is first.
__________________
Restore Performance, Reduce Costs
www.lubecontrol.com
Are you using the new soy based fp-plus?
________________________________________
Go Here For Real Medicine
http://www.youngliving.com/
Member 1025782
Jobs wanted in boulder or louisville colorado.
PM me if you know companies that are hiring.
gearbox is offline   Reply With Quote
Old 2 Weeks Ago   #3 (permalink)
greeen01civic4d
balls in ur mouth
greeen01civic4d's Avatar
greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold greeen01civic4d is a splendid one to behold
dude thats almost not possible, u would have a gigantic mess in the bay too, how do u kno its ps fluid?
__________________
signature courtesy of speedfoos(Thanks Clint)
go here for 7thgen resource
greeen01civic4d is offline   Reply With Quote
Old 2 Weeks Ago   #4 (permalink)
CraigW
Platinum Member
CraigW's Avatar
CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light CraigW is a glorious beacon of light
I would suspect a problem with the rack & pinion assembly. There is a round flange portion on the firewall that is leading into the steering column. It is most likely leaking internally and pushing fluid into the cabin.
CraigW is offline   Reply With Quote
Old 2 Weeks Ago   #5 (permalink)
MoeGalvez
New Member
There is no way to get oil inside the car, it is not coolant because it is oily and dark, transmission fluid it is imposible, so the only dark and oily fluid in the car is PS, besides when you lift the car in the front the power steering fluid tank gets emptied for no reason whatsoever, it just gets empty in front of your eyes (you can actually see the tank going lower and lower until it's gone.
Old 2 Weeks Ago   #6 (permalink)
MoeGalvez
New Member
I saw a lot of fluid in the engine, mostly by the boots, so I could be that the problem, I am going to check it today and let you know. Thanks for your help.
Old 2 Weeks Ago   #7 (permalink)
CraigW
Platinum Member
CraigW's Avatar
That is a lot of fluid !! It has to be dripping somewhere under the car if it is leaking under the hood.
Old 2 Weeks Ago   #8 (permalink)
MoeGalvez
New Member
Yes, it does, it has been dripping for quite some time. Didn't know what it was until it came inside the car.
Old 2 Weeks Ago   #9 (permalink)
CraigW
Platinum Member
CraigW's Avatar
At each opening in the front wheel wells are the 2 ends of the rack & pinion, Is there any fluid at either of those 2 ends ??
Is the dripping anywhere near the firewall ??
Old 2 Weeks Ago   #10 (permalink)
MoeGalvez
New Member
Going to check, will let you know
Old 2 Weeks Ago   #11 (permalink)
CraigW
Platinum Member
CraigW's Avatar
Here is a drawing, It is the only place I can imagine that any fluid can be getting inside. The round end of the flange is on the engine side of the firewall. It seems I remember reading of people having fluids leaking inside the car in this fashion ( other than coolant, rain water & evaporator drain water)
Old 2 Weeks Ago   #12 (permalink)
MoeGalvez
New Member
Thanks a lot!
Tags
2001 , 99 , car , civic , fluid , honda , inside , leak , leaking , lx , pinion , power , powersteering , ps , rack , steering
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
User Login
Our Partners
used new
Top 10 Threads
Maintenance required light
Your answer may be here! TSB / Honda Complaint Address / Etc...
ODB II Codes
Is your Check Engine Light, SRS Light, Or ABS Light On? If so, Please Read
Timing Belt DIY 2
DIY: Diagnose manual Tranny Noises (and save some $$$)
Who's had a bad transmission? *UPDATED*
7th gen civics and their common problems...
Warrenty law that Save's your a$$
Transmission - Jerky - Automatic - HELP!
Site Supporters
aluminum radiator
Honda car spoilers
