buzzing noise when turning the key
Old 07-20-2006
PiinkSox's Avatar
PiinkSox will become famous soon enough
Earlier this year I started to hear this buzzing noise when I turn the key to 'ignition'. It comes and go and it stopped for about 4 months or so and just last week it came back. It's gone for now...but what is that noise? Anyone know and how can I fix it?
Old 07-23-2006
RogerB's Avatar
RogerB is an unknown quantity at this point
I'm getting the same noise from my 05 Civic Coupe. Doesn't happen all the time but is annoying when it does.
And I haven't figured out what causes it either.
Old 07-23-2006
isnt that just the fuel pump working? it should only buzz for a few seconds.
Old 07-24-2006
Official Rattlesnake Hunter
02BLKCIVIC's Avatar
I thought it was normal...
mine does it too...
Old 07-24-2006
RogerB's Avatar
Hmmm... I don't think it's the fuel pump... It is fairly loud and it seems to come from inside the dash and not from under the hood. I can't say for certain that PiinkSox has the same issue I have, but it does seem very similar.
I usually turn the key back when I hear it.. and it stops. When I turn the key forward again it's gone. Maybe I should try to see if I can keep the key forward when it buzzes and see what it does. If it's the fuel pump then it shouldn't last long and the car will start right? If it continues to buzz for a while then I assume it wouldn't be the fuel pump.
It's just really hard to remember to keep the key turned forward. When my car makes a sound like it's in pain, I try to take away the pain.
Old 07-24-2006
cannonfolder's Avatar
cannonfolder is an unknown quantity at this point
maybe the ignition relay is defaulting or staying stuck
Old 07-25-2006
02BLKCIVIC's Avatar
But the car still starts every time sooooooo
Old 07-25-2006
indianaman's Avatar
indianaman is an unknown quantity at this point
my 01 ex does it also i found if i turn the key slowly it does it. fast it does not. it is the relay prolly dirty contacts.
Old 07-25-2006
k-man's Avatar
k-man is an unknown quantity at this point
yep my car does that too sometimes......took it to the dealer, they couldnt replicate it.....as usual........
its definately not the fuel pump....
Old 07-25-2006
cleansilver2001's Avatar
cleansilver2001 is an unknown quantity at this point
yeah I get that sometimes sounds like a crenging noise like I turned the key the wrong way. It comes and goes every now and then.
davidarenberg
05-16-2015 08:45 AM
ayoitzjulesdx98
05-13-2015 08:31 PM
edgenet
05-02-2015 08:00 PM
SSMatey
04-13-2015 06:09 PM
Quick Reply: buzzing noise when turning the key
