HELP!!!signal stays on when headlights is on?
Rep Power: 0 HELP!!!signal stays on when headlights is on?
please help! when headlights is off i can signal like normal but as soon as i turn the headlights on the signal stays on soild(just one side does this). when headlight is on the signal light stays solid but if i hit the harzard light it works but if i signal, nothing, just stays solid. bulb is good wiring dont look like its grounding.this start to happen rite after a fender bender on the same side.
Rep Power: 787 well ya its from the accident. i would look at the wiring, maybe its either grounding out or wires got crossed somehow
Rep Power: 0 even if the parking light is on, the signal light will stay on solid. but if no parking/head light is on then signal light works fine. the hazard light works even if any light is on. does the front light have a ground? i'm pretty sure it's a very small problem i mite have over looked, any other ideals?
Rep Power: 0 I've had the excact same problem because of my cai, my grounding wires seemed in place but under heavy force(daily driving), it lost contact briefly and my electronics were ****ed up... I also could'nt lock the doors with my remote, and my driverside window didn't do the "all the way up or down" anymore!! Just bolt it on really strongly and if you have a cold air which is bolted on your ground(like my injen cold air for d17)you should consider moving your ground or your air filter mounting. Hope this fixes your prob , good luck... Oh yes, just take off bumper and in the bottom right hand corner you will find your grounds.
Touge
07-28-2015 09:46 PM
Touge
Ottawa
07-18-2015 05:38 PM
Touge
07-18-2015 05:37 PM
