Engine Problem...
Old Mar 11, 2004
maxxam25's Avatar
maxxam25 is an unknown quantity at this point
Engine Problem...
Sup guys! I did this 2 things before my engine has this problem oil change, air/feul gauge tapped on oxygen sensor.
Everytime I start my car 1 minute after it rattles and looses its power, rattles and I can hear the noise of air sucking through my air intake. Is that probably the effect of the two things I did?
Old Mar 11, 2004
flotsamm's Avatar
Disconnect the guage and see if it runs any better... if so then theres your problem.
Old Mar 11, 2004
bhaz413's Avatar
Support your local 81
From: In the land of milk and butter, Massachusetts, US
bhaz413 is an unknown quantity at this point
i dont think that is causing the problem since he is only tapping into a sensor to read it. I have a A/F guage as well and have no problems.
Old Mar 12, 2004
maxxam25's Avatar
i did disconnect the air/fuel gauge and it works. Does that mean I can't tap any air/fuel gauge?
Old Mar 12, 2004
wiqqur's Avatar
wiqqur is an unknown quantity at this point
Hmm. I Dont know much about that, but i think you might try it agian and if it dont work then yes. Or you can try a different product.
Old Mar 13, 2004
maxxam25's Avatar
what product you prefer? autometer, apc? I have the ac brand....
Old Mar 18, 2004
wiqqur's Avatar
i like autometer =x i think its more exspenive
Old Mar 18, 2004
maxxam25's Avatar
do you think it's ok to tap it the one at the catalytic converter?
Old Mar 18, 2004
bhaz413's Avatar
i have a pac gugage. tamping a sensor to read it will not cause that problem. I followed the a/f guage DIY exactly and I am having no problems. This is on a 2k1 with 119k for miles. I think you need to check elsewhere.
Old Mar 31, 2004
J-spec-SiR2's Avatar
J-spec-SiR2 is an unknown quantity at this point
tap the cat one be done with it
Xuhme
21
Aug 7, 2023 03:40 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
bluecoupe
Jan 23, 2002 05:50 PM
Cross
Jan 6, 2002 01:31 AM
supercivic01
South
Nov 30, 2001 11:27 AM
