2001 Civic EX Cruise Control Not Working
Old 09-03-2016
skj88's Avatar
skj88 is an unknown quantity at this point
The cruise control in my 01 Civic Ex stopped working for me a while back and I am finally annoyed enough to try and fix it. It was working fine one day then stopped working the next. The green "cruise" light does not come on when I press the button by my left knee. Since the light does not come on I checked the fuse panels under the dash and in the engine compartment to see if one was marked "cruise" or something, but none are labeled anything close to cruise (see attached photos).
Any suggestions?
Thanks in advance.
Name:	2016-09-03 15.17.11.jpg
ID:	89083   Click image for larger version
Name:	2016-09-03 15.17.32.jpg
ID:	89084   Click image for larger version
Name:	2016-09-03 15.18.59.jpg
ID:	89085   Click image for larger version
Name:	2016-09-03 15.19.07.jpg
Old 09-04-2016
Re: 2001 Civic EX Cruise Control Not Working
If you mean the light inside the switch, it's just a light bulb that eventually burns out. That alone doesn't make the switch quit working, just make sure the switch is latched in the 'in' position.
If it won't turn on the light in the cluster, then the cruise isn't activating, could be a dozen possibilities.
Coupe or Sedan? They use different cruise systems.
Manual or automatic?
Does the horn work?
Airbag warning light on?
Check engine light on?
Fuses:
Dash box #4, 10
underhood box #7
Old 09-05-2016
skj88's Avatar
Thanks for your help.
Yes, the cruise button is pressed in. The light in the dash does not come on when I press it. I was thinking that might be a clue to what might be wrong.
It's a manual trans four door. Horn works. No airbag lights or check engine lights. I checked the fuses you mentioned and all are fine.
Old 09-05-2016
Stock taillight bulbs, brake and tail lights all work (and work correctly), no LED lights?
Component list:
Main switch
set/cancel/resume switches on steering wheel
Clutch switch
brake pedal switch
Cruise control unit
Engine control unit or VSS signal
cable reel (clockspring)
actuator and cable
and the cruise light on the cluster.
plus a ton of wiring
I'd check brake and clutch switches, maybe one of the little rubber bumpers broke apart and can't push on a switch plunger.
Then I'd get a wiring diagram and voltmeter out and start testing.
Probably can check most individual components electrically from the connector of the cruise control unit..
Old 04-01-2022
Zjwood's Avatar
Zjwood is an unknown quantity at this point
Component list:
Main switch
Clutch switch
brake pedal switch
Cruise control unit
actuator and cable
I know this thread is 6 years old but did anyone try this?
Old 04-02-2022
Colin42's Avatar
Received 1,131 Likes on 945 Posts
Try what?
Old 04-22-2022
Originally Posted by Colin42
Try what?
I'm guessing "the shopping list".
The following users liked this post:
Colin42 (04-22-2022)
Old 04-25-2022
NDNV's Avatar
NDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of lightNDNV is a glorious beacon of light
The following 3 users liked this post by NDNV:
Colin42 (04-25-2022), FRSam (04-25-2022), sdaidoji (04-25-2022)
Old 04-29-2022
Emmaleigh's Avatar
Emmaleigh is an unknown quantity at this point
I'm having a similar problem.
When I press the cruise control button on the left of the wheel I got a green light.
When I try to set the speed with the switch on the wheel I got no response.
I bought this car used a year ago.
​Curise control didn't work the first few times I tried it, then it worked once a month ago but I haven't been able to get it to work since.
Srs light is on
​​​No other issues
Old 05-02-2022
NDNV's Avatar
Cruise control cannot be set:
  • check the main switch
  • check the SET/RESUME/CANCEL switch
  • check the brake pedal position switch and its mounting
  • check the transmission range switch
  • check the cruise control unit inputs
  • check cruise control actuator
Get the code scanned for the SRS code. Chances are it is related to the driver's seat belt buckle switch - common issue.
Old 05-08-2022
Emmaleigh's Avatar
Can you give me any info on how to check the set/resume /cancel switch?
I scanned with an OBD2 and no fault codes came up.
Old 05-23-2022
AmberSti.'s Avatar
AmberSti. is an unknown quantity at this point
I have the exact same problem and have the same car but also my key fob doesn't work either which is super annoying because someone broken into my car a few months ago and they got in by taking my whole door handle and lock out of my driver's side door so when I unlock my car I have to go in through my passenger side so it's really annoying
Old 03-26-2023
Robertlx's Avatar
Robertlx is an unknown quantity at this point
This test works with a multimeter(set/cancel/resume;test is near the end of the video) but make sure you have the multimeter set to the continuity position.
quartermilecame
Electronics
06-23-2021 04:05 PM
Macleen1229
07-04-2016 09:35 AM
dipmo13
06-14-2015 08:32 AM
fecomosis
09-09-2012 07:53 AM
DieMaster
10-13-2006 08:28 PM
Quick Reply: 2001 Civic EX Cruise Control Not Working
