SRS light on
Old 04-05-2014
woodsjd1's Avatar
woodsjd1 is an unknown quantity at this point
SRS light on
last nite I blew a low beam fuse on my 95 HB...when I went into the fuse box to replace it, I thought I was pulling a spare fuse, but turned out it was the SRS fuse...I put it back in, but now my SRS light is staying on...I tried to reset (pulled the back-up fuse from under hood) but it's still on....I did this hot (battery connected) but didn't think changing a fuse would cause a problem....
what have I done this time???? this site is great...better than my Honda dealer and a whole bunch cheaper....thanks all
Old 04-05-2014
Re: SRS light on
https://www.civicforums.com/forums/p...550-post1.html
See if this will work for your car
Old 04-05-2014
woodsjd1's Avatar
Re: SRS light on
did not work.....after the 6 seconds, it flickers (if flicker is faster than a blink) but stays on....info said this would only fix it if whatever caused it to code was first fixed...I think it coded because I turned on the ignition with the fuse (SRS) removed....maybe it didn't work because this fix was for a 2001 and Im a 95....any ideas of how to erase SRS memory on a 95 civic hb??
Old 04-05-2014
Re: SRS light on
Maybe you should read the code to see why the warning light is on.
Burnout
07-15-2022 10:24 PM
Blazz
05-25-2015 10:56 PM
cukaracha
05-16-2015 02:11 PM
XtremelySpoiled
12-13-2001 08:47 PM
SimDogg
11-27-2001 04:20 PM
Quick Reply: SRS light on
