Electric locks draining battery?
Old 01-23-2016
wiljamus's Avatar
wiljamus is an unknown quantity at this point
I bought a '96 Civic for my son's first car. What i thought was a bad battery seems to be a drain from the electric door locks. Using a VOM a friend and i isolated the drain on the battery to the fuse for the door lock circuit. Since removing the fuse the battery seems fine. Any suggestion would be appreciated. I would like to get that circuit working properly.
Old 01-23-2016
Re: Electric locks draining battery?
If you install the fuse, do the power locks work CORRECTLY? If anything at all doesn't work as designed, that's probably a good place to start looking.
Any aftermarket equipment under the dash? Alarm, remote start, etc?
Wiring diagram, voltmeter/ammeter, isolate sections...maybe see if a power lock switch is stuck on. Maybe the door lock (key cylinder) has a switch on the back that has broken, forcing the system try to lock (or unlock) the doors all the time.
Old 01-26-2016
wiljamus's Avatar
There is no alarm or other aftermarket equipment that i know of. Of the locks; passenger front and both back work properly as far as i can tell. The driver's door must be locked with the key once you are out of the car. It locks the same as the rest but opens when you close the door. I figured that's a feature to keep you from locking your key in the car. Otherwise it works as expected. i will check the locks with the fuse in. On of them has to be the culprit - drawing current all the time. Or maybe it's a switch. Thanks for the suggestions.
Old 01-26-2016
To lock while drivers door is open: Pull out on the outside or inside handle then use the lock button (Manual or power).
This is in the owners manual if you still have it.
se7en
02-15-2004 02:49 PM
HaRdKoRePinoYrAcer
01-05-2002 09:16 AM
05civic
12-23-2001 08:34 PM
Dreamer01
Detailing
12-22-2001 10:17 AM
Macko
Exterior
11-19-2001 10:34 PM
Quick Reply: Electric locks draining battery?
