Brakes Post your questions about Brakes problems here!
Possible wheel bearings going bad?
Old 04-11-2016
Caelidh's Avatar
Caelidh is an unknown quantity at this point
I have a 1998 Civic LX and I have gotten Tires replaced recently (full set) and the car seems to be running OK. HOWEVER, in the past month I started to hear a squeal coming from my drivers side front wheel.
It would come and go but over the last week or so it has gotten worse and I was at an AUTOZONE for an unrelated issue and the guy said he heard it from my right side as well. (as I was backing out)
This morning as I was backing out THIS morning it was really loud and squeely. It isn't the breaks (I just had those replaced a few years as well) and is when I am moving not breaking.
They said it probably is the BEARINGS???.
This just cropped up in the last month.
I think I probably also need my clutch replaced too.. but I am more concerned about this noise!.
Could this be the bearings? I don't notice any lessened driving performance. (no shaking or rumbling or thumping) just the squealing noise. (especially when I am backing up )
I am trying to avoid the dealer as I fear they are going to be SUPER expensive. How much will this set me back? and how serious /dangerous is it? I do drive a long commute.
Thanks
PS: I also live on a gravel pothole filled road and I wonder if that has contributed to this problem. (which annoys the HELL out of me because we live with 20 other people)
Old 04-11-2016
Super Moderator
Poopies's Avatar
Re: Possible wheel bearings going bad?
How do the rotors look/feel? It it is the bearings, they shouldn't be too hard to replace. You just need to get the wheels, calipers and rotors out of the way first. There are DIY articles on that, and good replacements aren't THAT expensive. I don't know about squealing, but my rear ones sounded like an old WWII bomber before I replaced them.
Old 04-11-2016
mikey1's Avatar
from what you have described here the noise does not sound like its a wheel bearing, you generally would not be able to hear wheel bearing noise going at a slow speed or backing up like you are saying,
to hear a wheel bearing noise you would need to be going about 20-30mph at least, and the noise would get louder and consistant with the speed you are travelling, generally sounds like a humming or buzzing sound, not a squeal
Old 04-11-2016
They usually sound like an airplane flying next to you by the time people bring them in to the shop with a complaint.
Old 06-29-2019
My notes say that wheel bearings should be repacked every 12K miles.
Do you have a service manual specifically for your own car?
I don't know what car you have, but sealed bearings have been in use for decades.
Old 06-29-2019
tmst's Avatar
tmst is an unknown quantity at this point
Manual? I don't need no stinkin' manual!
Actually, I consulted it and found my Civic has sealed bearings! Can you believe that? How the heck did that note about repacking the bearings get in my notes? It's a conspiracy, I tell you! The body snatchers found my notebook. Agh!
Doug Lassiter
Wheels and Tires
03-16-2014 10:30 AM
mikey1
04-21-2013 12:09 PM
rechinca
Suspension
03-04-2013 07:12 PM
nyron
04-10-2012 06:08 PM
Lord ET
06-24-2007 12:16 AM
Quick Reply: Possible wheel bearings going bad?
