Header/downpipe help!
Old 10-14-2012
PowWow's Avatar
PowWow is an unknown quantity at this point
what size studs am I supposed to use? i got a stock ex header and manifold
Old 10-14-2012
Re: Header/downpipe help!
The exh. man. studs in the head are 8mm X 38mm X probably 1.25 thread.
The studs at the bottom of the manifold should be 10mm
Old 10-14-2012
PowWow's Avatar
what kind of tool am i supposed to use to tighten it
Old 10-14-2012
Whachya lookin at?
BlueEM2's Avatar
What I do is hand tighten the studs. Attach two nuts facing each other near the end of the stud, use a torque wrench and torque the studs to 23 ft/lbs using the exterior nut. It doesn't need much. Then you remove the nuts and put the gasket + manifold.
Old 10-24-2012
PowWow's Avatar
Thanks for the info but s'all good! Got that done bout a week ago and I finally just finished putting on the rest of the exhaust piping/muffler.
joemommaaa
Bolt-on Engine Performance
12-20-2013 06:55 PM
nick82006
10-07-2009 04:52 PM
youngjosh12
15
05-20-2009 12:04 AM
youngjosh12
04-23-2009 10:26 PM
04trinicivic
04-08-2006 07:17 AM
Quick Reply: Header/downpipe help!
