98 Civic erratic idle when warmed up
Rep Power: 0 98 Civic erratic idle when warmed up
I have a 98 Civic automatic. When you start it up cold, it runs fine. as soon as it warms up the idle bounces from 1000 rpm to 1800 rpm every 2-3 seconds. When you accelerate it smooths out. No codes are showing. Any thoughts as to what is causing this ? I replaced the O2 sensor hoping this was it but no change.
Rep Power: 176 Re: 98 Civic erratic idle when warmed up
Idle
Air control valve to make sure that it is, remove intake tube and look inside the throttle body you will see a hole which is vacuumed, wear some rubber glove and block that hole and watch the engine return to normal,do this when its surging
beneditti
01-15-2016 12:31 PM
Civicchicky87
Idle Issues
04-22-2015 07:16 PM
vtechcivic
04-21-2015 06:58 PM
streetglower123
04-12-2015 10:56 AM
