2000 LX - Exhaust Manifold replacement without the cat
Old 07-17-2012
johnnyrooskie's Avatar
johnnyrooskie is an unknown quantity at this point
2000 Honda Civic LX has a crack in the manifold near the upper 02 sensor. I'm over 150K so no dice on the consent decree settlement thing. My question is, can I just replace the manifold without replacing the cat? Most searches for the manifold have the mani/cat combo or a performance header/mani. Is the manifold detachable from the cat. Finally, anyone got an opinion on welding the crack. A guy at Autozone told me about a muffler shop down the street that'd do it for $25. Thanks in advance!
Old 07-18-2012
Lord Sin
Lordsin's Avatar
Lordsin is an unknown quantity at this point
Re: 2000 LX - Exhaust Manifold replacement without the cat
Yeah you can replace the manifold and leave the exhaust
Old 07-18-2012
Lord Sin
Lordsin's Avatar
Don't weld it because if it doesn't hold you do more damage than good
Old 07-19-2012
How so? Damage to the manifold? If that's the case, the manifold is already cracked and if it doesn't hold, then I end up replacing it anyway. I just figure it's worth it to try the cheap fix first. If that doesn't work, then I go all in for a new mani.
Old 07-22-2012
Lord Sin
Lordsin's Avatar
Lol 15$ is cheap for a used manifold.
Old 07-27-2012
TheFalen's Avatar
TheFalen is an unknown quantity at this point
i need a new manifold my self let me know how it goes.
Old 07-27-2012
Aetoc's Avatar
Aetoc will become famous soon enoughAetoc will become famous soon enough
The manifold and cat are sold as one piece...the only way to replace the manifold alone, is to convert the exhaust to the EX exhaust and get an EX cat, so the cost is just the same, if not more...your best bet is to have the crack welded by a skilled welder, and save up enough to have the whole thing swapped.
Supramk3
05-11-2015 07:55 PM
What_It_Do
05-10-2015 05:31 PM
Civic4ever1996
04-16-2015 08:30 PM
thesushiboy
04-12-2015 02:54 AM
AEMcivic
12-05-2001 04:02 PM
Quick Reply: 2000 LX - Exhaust Manifold replacement without the cat
