Help with Alpine Component Crossover
Old Aug 2, 2005
Wizkid's Avatar
Wizkid is an unknown quantity at this point
I just purchased the Alpine 6.5 component speakers. My only problem is that I don't know where to mount the crossovers that came with the set. I need to screw them down so that they don't move around, obviously. But I really don't see any space in the door to mount them without conflicting with anything else.
I have already installed the set, but without the crossovers installed. The 6.5 's sound good, but the tweeters are distorted with any kind of high output.
Any help would be great.
Old Aug 2, 2005
chriscivic's Avatar
chriscivic is an unknown quantity at this point
for now, my type r's crossovers ar ein the glovebox, i will find somewhere nice for them one day.
Old Aug 2, 2005
VTEC01EX's Avatar
VTEC01EX is an unknown quantity at this point
Mine are behind the kick panels on either side of the car. Perfect spot for them, protected from the elements and pretty easy to access if needed (much easier than inside the door).
Old Aug 2, 2005
Kyle23's Avatar
Kyle23 should not be trustedKyle23 should not be trusted
OMFG! Dont play those speakers w/o the crossover! U could kill the tweets w/o the xover. If they r receiving the midrange and bass singals (which it sounds like they r) they will blow cuz they r only meant to handle the highs.
I have mine behind the door panel. I used a backstrap (things used on the back of some CD player installs to hold them) and some velcro. Just bend the backstrap so that the x over is supported then put a piece of velcro on the backstrap and on the x over and then connect them. then just put a few screws into the backstrap to the metal on ur door. then u can hid it all behind the plastic insulation **** so that it will stay there even if the velcro breaks (which it wont) or a screw comes loose.
Old Aug 2, 2005
Wizkid's Avatar
yeah, i heard the distortion when I originally started it up afterwards. I pretty much haven't used my stereo since, until I have the time to do it today. If they are damaged now, I still have the nice warranty coverage on them...
Old Aug 2, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
i just used a hot glue gun and glued them to the inside of the door in where the driver mounts
Old Aug 2, 2005
KnocturnalEM2's Avatar
I am your Mom's Hero!!
You could also mount them inside the center console above the cup holder in that space!!
Old Aug 2, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
^mount them in the door with hot glue.
That is how the pros do it.
If you do not then you will have to mount the tweeter some where other than door and that can be a pain. Unless you wanna try to get wires through that door gromet, which is near impossible.
kicker easier than door panel, it takes like 2-3 minutes to get door panel off, and there is a perfect spot for them in the panel where they are safer.
Old Aug 3, 2005
Wizkid's Avatar
i ended up putting them behind the kick panel on each side. I did run the wires through the grommet on the doors. It really wasn't as hard as i thought it would be. The trick is to disconnect the 2 plugs on each side underneath the dash. Then just remove the grommet and pull it through to the door. Then just use a long screwdriver and some tape to pull the wires through. Definetely took a bit longer, but completely worth it. You can't even tell its there, and its still easy access to the crossover. I'll try and post some pics to show you.
Old Aug 3, 2005
jackburton's Avatar
I was thinking that the time it takes to run wires through grommet would be more than taking door panel off a couple of times.
Old Aug 3, 2005
Wizkid's Avatar
only took about 10 min to run the wires once I realized that I could just pull everything through to the door.
Old Aug 3, 2005
nick95673's Avatar
go buy a huge zip-tie and cut the tips to a point then you can tape whatever wire to one end and use it as a fisher thru tight long curved spaces
Mad Dog Tannen
Oct 19, 2016 08:12 PM
ZoSoIV
Sep 17, 2015 07:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
violentpanda
Sep 7, 2015 11:49 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
