sub with stock deck?
Old Sep 26, 2004
Cyberkinetic's Avatar
Cyberkinetic is an unknown quantity at this point
This may be a dumb question, but bear in mind that I don't know much about car audio. I'd just like to know if you could hook up a sub to a stock 01' cd deck. I'm only asking, cuz I prefer the way the stock one looks as opposed to aftermarket ones which often tend to look out of place because they don't blend in with the dash.
Old Sep 26, 2004
yes you can.. i have 2 10"s hooked up to my stock deck... dont ask me about wiring and stuff cuz my dad basically did all that for me... i think we routed the wires going to the back speakers through the amp and subs and stuff, and then to the rear speakers.. or something like that...
Old Sep 26, 2004
Thanks man, thats all I need to know. My buddy knows everything there is to know about car audio, so he can help me. How does it sound with the amp and subs? Is it a lot louder with the amp?
Old Sep 26, 2004
i'd say its an improvement.. i can bump my system when i want to... the way my setup is, the amp also affects the rear speakers.. or so my dad said...
Old Sep 27, 2004
MegaHurtz's Avatar
You can hook an amp to your stock deck but you will have to use either a line level converotr an amp with high level inputs.
Why not replace the POS stocker?
Old Sep 27, 2004
SiG's Avatar
SiG
I had that setup for a while
Had my stock deck, and hooked my subs up to the rear speakers. I used a switch under the steering wheel to turn the amp on. Didnt sound bad, but with the aftermarket deck, its MUCH better.
Ya just got splice into the rear speakers and connect those to the subs with some wire. Words of advice, find a good ground and secure it well
Old Sep 27, 2004
mugenman's Avatar
"mmmBAHHHH" - vtec y0
yup sure can. ive got 2 12 inch infinitys and a 250 watt jl audio amp. im holding out for a indash dvd player. but i might get a nice jvc one to go along with my led conversion im doing over winter break just so everything is blue
Old Sep 27, 2004
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
First of all, asking a dumb question would be either asking something you should be able to answer with common sense, or asking something you already know the answer to. I hate to see people preface a question that way. The reason we have these forums is so people can ask questions. That being said, obviously you see your answers above here that you can do it with a Line level converter. But I did want to suggest to you if you are interested in an aftermarket HU, Apline's 98-- line has a couple of models with 512 different illumination settings, like the 9831-9833-9835. The 9833 is an excellent match all around, buttons and display to the civic dash.
Old Sep 27, 2004
v8eaterokv6's Avatar
i have a new home do u
i got a question about using the stock deck. is the stock keyless entry incorperated into it
Old Sep 27, 2004
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
no, its not incorporated into the deck.
Old Sep 27, 2004
NoLeadEmSoMuch's Avatar
NoLeadEmSoMuch will become famous soon enoughNoLeadEmSoMuch will become famous soon enough
sometimes stock deck and speakers are a bad idea - the stock deck might not supply enough wattage to the aftermarket speakers and/or too much distortion...caused one of my rears to blow while still on the stock deck. Replacing stock deck tomorrow
Old Sep 27, 2004
BlueTroll's Avatar
BlueTroll is an unknown quantity at this point
that was what i had as my very first setup.... i had the stock deck, speakers and a crappy 10" sony sub... which totally sucked... but anyway....
i thought it was terrible.... the sub would drown out EVERYTHING else... all i would hear was sub.... so i ended up buying a deck and front speakers.... made a world of difference... then an amp for the front speakers.... ugh... and thatz how it all started.
Old Sep 28, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
^ it always happens that way.
I guess you could splice into the rear speaker wiring - but that's ghetto. I'd think minimally you'd need an amp that can bridge.
Old Sep 28, 2004
J187's Avatar
What do you people that actually LIVE in the ghetto say to describe something low quality??
Old Sep 28, 2004
thom's Avatar
/////ALPINE
i had this setup at one time in my car.
i needed to get that thing you said so it can connect to my stock HU.
but when i upgraded my HU...WOW.. improved sound! totally.
clean crisp sound
Old Sep 28, 2004
J187's Avatar
Not wanting to spend the money on a new HU isn't really a good reason to use a LLC. A good reason would be if you had an Audi A4 where nearly the entire dash console is made up of the headunit and its bright red lights. It might look pretty dumb if you put in an aftermarket din-sized unit. Thats a good reason for the LLC. The ugly radio in the 7th gens has to go!
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
Jul 12, 2015 11:54 AM
BootyDo
Jul 7, 2015 06:06 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
