Component setups...
Old Aug 17, 2004
civicrice's Avatar
civicrice should not be trustedcivicrice should not be trusted
Component setups...
i have an lx coupe, and it doesnt have the tweeters in it. i wanna get the infinity component speakers. but where can i mount the tweeter. would it fit on the plastic thing where the ex's have their tweeters?
Old Aug 17, 2004
MegaHurtz's Avatar
If they come with surface mount hardware you can use that and surface mount the tweeters either on your sail panels or dash.
If they come with flush mount hardware, you can flush mount them wherever you like as well, either in the sail panel, door panel, or dash if you want to go a little more complex on the install
Old Aug 17, 2004
turboslug's Avatar
Super Hoser
turboslug will become famous soon enoughturboslug will become famous soon enough
go buy the stock tweeter pods from the dealer and mount them in there...
i personally think tweeters in the stock location looks best...flush mount on the door is ok too but i still prefer the pods.
Old Aug 17, 2004
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
try kick panels, it will look and sound best...
Old Aug 17, 2004
civicrice's Avatar
how can u hear it if its all the way on the floor. and any idea how much stock tweeters from the dealer are?
Old Aug 17, 2004
MegaHurtz's Avatar
The sound will project up.
A good set of kick panels will make u think the sound is coming from the center of the dash
Do NOT buy the stock tweeters, they are crap. Buy the stock tweeter pods (sail panels designed for tweeters) and put aftermarket tweeters in them. You can get a component set and put the 6.5" woofer in the door and the tweeter in the sail panel.
Kicks are a lot better though, you get a much much better sound out of them
Old Aug 19, 2004
slammedcivic85's Avatar
Member
slammedcivic85 is an unknown quantity at this point
my components are set up like so i like the sound i get from them but im still gonna make the switch from jl audio to memphis audio components in the near future ignore the car being dirty ima busy man lol
but you get the picture
Old Aug 19, 2004
PopcornPlaya's Avatar
Electric Boogaloo...
Like the others said, go to the local honda dealer and get the EX sail panels.
Old Aug 19, 2004
MegaHurtz's Avatar
Yeah the EX sail panels look real nice
If you want better quality sound though, I say mount them real low, right by your woofers and aim them up towards the center of the dash
Old Aug 20, 2004
scbgilbert's Avatar
scbgilbert is an unknown quantity at this point
the sail panels are good ... if you wanna try something different try mounting them in the center dash vents .... one of my friends did that with his dakota and it sounds crazy wicked ... plus he got extra pounds in a car show for that
Old Aug 20, 2004
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
umm yeah... those little tweeters should have no problems fitting in the sails if i can do this with mine...
Yeah those are 4 inch vifa tweets.
Old Aug 20, 2004
doubledeuce2k2's Avatar
OMG those look unholy! props for putting some nice speakers there, and it's as clean as it could be, but that looks like a goiter on the mirror or something
Old Aug 20, 2004
auto84's Avatar
I R T3H 1338
lol, i know but it sounds badass...
Old Aug 21, 2004
HondaSales's Avatar
WTF???
Old Aug 21, 2004
I just got some separate intinity tweeters and did a surface mount. Looks pretty clean and brings up the sound stage.
Yeah they angle away from you, but it sounds really nice without being harsh.
Old Aug 21, 2004
MegaHurtz's Avatar
I like it when they are not angled right at you, it helps the speakers to not be localized, as long as they fire into a good spot in the dash that is perfect
Old Nov 1, 2004
JP375's Avatar
JP375 is an unknown quantity at this point
Anybody have a DIY wor taking the EX tweeter pods off? Can't seem to find one, and the door DIY removal isn't the greatest.
Old Nov 1, 2004
HondaSales's Avatar
how can you create a sound stage with the tweeter so far away from the mid?
Old Nov 1, 2004
coop's Avatar
coop is a jewel in the roughcoop is a jewel in the roughcoop is a jewel in the rough
the only difference with the stock EX panels is that it positions the tweet a bit different - nice job btw.
Old Nov 1, 2004
bzrollin's Avatar
bzrollin is an unknown quantity at this point
Uhh, to take the EX tweeter pods off, you just pull it from the top straight toward you, then slide it slightly up once you release the clip. Just roll your window down and you should be able to get ahold of it.
Old Nov 1, 2004
LudlamTheory's Avatar
i boogie for the raindrops
that actually depends on the driver's on and off axis performance. some tweeters are designed to be aimed right at you, some are designed to be aimed away from you. for actual directionality of stuff, midrange is infinitely more important in creating a proper soundstage.
Old Nov 1, 2004
Adawg's Avatar
Adawg is an unknown quantity at this point
what does on axis mean?
Old Nov 1, 2004
fonto's Avatar
The LA Clipper
on axis = facing you (usually with the passenger side speaker aimed at the driver, and the driver's side speaker aimed at the passenger).
off axis = not facing you
Old Nov 2, 2004
JP375's Avatar
I'm a noob when it comes to component speakers. I want to get some and put the tweeters in the stock EX pods. Do they usually take much modification to make them fit? They are 1" tweeters. Not sure what size the stock ones are. Also, what do the manufacturers mean when they say they inlclude a surface and flush mount kit? I realize its the type of mounting, but what exactly is in this "kit" they are describing.
Old Nov 2, 2004
coop's Avatar
1" will work just fine
The "kit" includes plasticware that allows you to mount them in a pod that you mount on the surface (it will stick out) or flush mount means the plastic pod with tweeter installed would sit in a cut out just under the pod size.
Old Nov 21, 2004
2slow2run's Avatar
wut time is it now
2slow2run is an unknown quantity at this point
the whole thing for the door tweeter is bout 35 bucks n the cover is 7 a piece but they took so long on the tweeter so they gave it to me for like 3 something a piece
Old Nov 21, 2004
It's easy to install on the empty panel. I drilled one hole and used a screwdriver. The rest is running wires to the deck or amp. Sounds very good.
Mad Dog Tannen
Oct 19, 2016 08:12 PM
ZoSoIV
Sep 17, 2015 07:17 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
violentpanda
Sep 7, 2015 11:49 AM
protoCall7
Bolt-on Engine Performance
Jul 26, 2015 07:41 PM
