2009 Civic sounds distorted with bass up.
Old 08-28-2015
Deeup511's Avatar
Deeup511 is an unknown quantity at this point
I keep my bass at -6 so it won't sound distorted. But as soon as the bass hits at anything higher than -6 the sound is really distorted. What causes this? Is it the amp, speakers, sub, anything else?
Old 08-29-2015
TiggerDX's Avatar
TiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of lightTiggerDX is a glorious beacon of light
Re: 2009 Civic sounds distorted with bass up.
Depending on the music and volume level, if you can't have the bass at 0 (flat) then your speakers are most likely damaged. Any stock stereo should be able to go near full volume with the bass level flat.
Old 08-29-2015
I have not really seen speaker issues here, but I've seen a few with rear shelf rattles that make buzz and fart noises.
Even found one with a piece of broken plastic (came off the shelf trim) bouncing in a speaker cone.
One of the seat belt reels in my car makes a buzz noise when the radio is on low.
Old 08-30-2015
jordan1794's Avatar
jordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nicejordan1794 is just really nice
Is it an Si with the stock woofer?
I've heard them and IMO they sound like crap.
The first time I heard one I thought it was busted.
(But I'm spoiled by mid to high end audio equipment)
Could get a multi-meter and check the resistance of the speakers, I believe all the speakers in the entire car should be 4 ohms.
anything less than 3.8-3.9 ohms on the woofer would indicate the coil is certainly damaged.
(Should really be at 4.0, but i assume there is some play, especially with the stock woofer)
Jonnie.
01-13-2019 11:21 AM
usajags84
05-10-2015 08:11 AM
tylerginevan
04-27-2015 12:29 PM
LionSpratt
04-26-2015 01:02 PM
ej8
04-13-2015 06:36 PM
Quick Reply: 2009 Civic sounds distorted with bass up.
