LIMP MODE! - 2007 Honda Civic
Old 01-02-2016
Johny Roque's Avatar
Johny Roque is an unknown quantity at this point
I had a misfire in cylinder 2 and changed the spark plug and coil and it doesn't misfire anymore at the same time it was stuck on limp mode before that issue. Now the car doesn't have anymore misfire but its still stuck on limp mode. I tried disconnecting the battery (doesn't work) tried takin out the fuse in the fuse box (doesn't work) anyone know how to fix this. AutoZone and all these places don't reset the codes because its the law here in florida.
Old 01-02-2016
Re: LIMP MODE! - 2007 Honda Civic
Is the misfire code gone now? If disconnecting the battery got that code to erase, then it should erase any other engine codes at the same time.
Unless it still has an unfixed fault code (Check engine light still stays on?), or a deeper problem the computer cannot detect.
Try different code readers, maybe there's manufacturer-specific code the generic readers cannot display?
Transmission problem?
What are you calling 'limp mode'? What is it doing?
KoiFish
11-06-2015 06:25 AM
Hani4g
10-31-2015 02:09 PM
ftareen
10-28-2015 12:51 PM
Mv7fd
10-12-2015 05:09 PM
Stussey21
Regular Maintenance
10-12-2015 07:23 AM
Quick Reply: LIMP MODE! - 2007 Honda Civic
