Strange Squeak and TPMS
Old 08-14-2014
iloch138's Avatar
iloch138 is an unknown quantity at this point
Hey guys, wife has a 2010 honda civic lx 4 door, its used as a daily work driver. She has been complaining of a random low speed squeak that until the other day I wasnt able to recreate. I was sitting in traffic and after releasing the brake and allowing the car to start propelling itself I could hear a squeak that seemed to rotate-- ie-- squeak...squeak...squeak...
The sound would go away if i pressed the brakes or once I sped up enough. after a little while i wasnt able to get the sound to come back, then again today got it to repeat with the same findings. Any advice? Im leaning towards wheel bearings but unsure.
Also her TPMS light came one the other day and as im unfamiliar with repairing that system im not sure how to diagnose which sensor is bad. Thanks in advance!!
Old 08-14-2014
CraigW's Avatar
Re: Strange Squeak and TPMS
What's the thickness of the front brake pads remaining ???
Which tpms light are you getting ??
Old 08-14-2014
iloch138's Avatar
im at 5mm on the front pads- Usually change them at 3mm- give or take motivation.
The TPMS light- their is the low tire pressure light and the actual TPMS light- owners manual says its a fault somewhere in the system.
Old 08-14-2014
iloch138's Avatar
Its strange, whenever I have had a pad issue in the past it only squeaked when I applied the brake- in this instance the squeak goes away when I brake.
Old 08-14-2014
CraigW's Avatar
Use the inspection slot toward the front of caliper and check the inner pads, my outside looked ok, but inner was scary. (at 75K miles for me)
What's the total mileage ??
Old 08-14-2014
Because the squealer is on the leading edge-- if the pads were installed correctly. Tab design allows more vibration when in reverse, at first contact.
If the pads were installed with the squealer on the trailing edge, it would probably make more noise going forward...at first.
Craig is right, these often wear the inboard pad faster than the outboard pad. The pad can wear at a slight angle too, so one end may be much thinner than the other.
The butt icon (_!_) is low tire, the TPMS word is a system problem. The typical cause is a dying or dead sensor, but the other day someone posted here that her cellphone charger was causing her TPMS light to come on due to RF interference.
GolNat
11-27-2018 03:32 PM
h4ldol
04-24-2017 08:16 PM
czarlun
09-14-2015 08:16 PM
Balkos
09-11-2015 11:39 PM
Quick Reply: Strange Squeak and TPMS
