08 Civic center console help (latch)
Old 08-04-2014
purplepills's Avatar
purplepills is an unknown quantity at this point
My center console will not close (latch issue). So I took it apart and realized one of the loops that hold it in place snapped. I found the piece and glued it back in place. But I cannot seem to understand how the spring is set up for the latch. One piece obviously goes into the latch itself. But for the life of me cannot see how/where the other piece of the spring clips to or fits in that allows the spring to have that springy action that closes the lid.
Any ideas?
PS I saw a couple posts here about this, but those all speak to buying a new piece. Not so much fixing it. Any input appreciated (Sorry if this has been asked, but I did search first).
Old 08-05-2014
CraigW's Avatar
Re: 08 Civic center console help (latch)
Have you looked at 8th gen site much ?? Quite a few threads and info.
Old 08-05-2014
I did use forum search plus a google search led me here. I found some posts on this. But none that said how to attach the spring.
Old 08-05-2014
CraigW's Avatar
http://www.8thcivic.com/forums/mecha...ht=armrest+lid
So you have no spring action at the release latch... correct ??
Old 08-05-2014
Thank you!!! And yes that is correct no spring action in latch. Through your link I found...
http://civic.hondafitjazz.com/A00/HT...404KBAT00.html
Should help a bunch... Again thanks.
Old 08-05-2014
CraigW's Avatar
I see a coiled spring to provide return.... maybe the tail at one end or other came loose and lost tension.
Or was the part that came loose that you glued back.
Old 08-05-2014
On the latch there are some loop like plastic pieces that came loose. THat allowed the latch to get out of place, also bringing the spring with it. One end of the spring obviously goes into the latch as there is a hole for it. But the other end has no such indicator. The diagram I found from your link may shed some light on that. The actual latch and spring seem to be just fine. It is just the mechanism that holds each in place that failed.
Old 08-05-2014
CraigW's Avatar
Sounds like the latch has broken where the metal pin goes to pivot/hinge and also secure latch to lid.
Only one end of spring will be in latch, other will likely be held tight to lid.
I think those latches breaking are common. Has a fair amount of spring tension.... and it's plastic.
Old 08-08-2014
BTW, I fixed my latch. Also it appeared the slide feature of the arm rest was broken. I also fixed that compliments of the link CraigW provided.
Thanks!!! Great community here.
Old 07-29-2020
Jessica Arciola's Avatar
Jessica Arciola is an unknown quantity at this point
HELP! 👋 So my console wouldn't stay shut so I bought the Latch piece (cause that's what I figured was the problem) and installed it myself from watching a YouTube video. But still having the same problem. So I'm thinking maybe I have the same issue as the OP but I don't understand the instructions.. Where would I take my car for someone to repair this? Honda? A body shop. A regular mechanic? I don't know. I just bought this car last year used. Thanks if anyone ever comes back here i would appreciate it.
cloudguy
04-28-2015 05:02 AM
cperez53
04-16-2015 09:31 PM
GH04si
04-15-2015 08:13 PM
Killagi
04-12-2015 10:42 AM
TopFuel
Exterior
11-13-2001 07:05 PM
Quick Reply: 08 Civic center console help (latch)
