sometimes drops rpm
Rep Power: 0 sometimes drops rpm
I have a 2012 civic lx auto and at stoplights it sometimes drops 100-150 rpms and will act like it wants to sputter. sometimes it does this sometimes not. It also catched itself sometimes and goes back to normal idle. The airfilter was black and dirty. Should I clean the maf too?
Re: sometimes drops rpm
11k miles.
But do not be surprised if you are told it is "normal".
It might very well be normal.
While you are on the dealers lot, test drive an identical car. That might demonstrate that they all do it and it is normal. Or not.
BTW: A dirty air filter does not affect your gas mileage.
If the air filter was doing its job properly, there is no need.
If fuel trim numbers don't indicate an issue, there is no need.
MAF is not normally an issue (not the way Ford's MAF sensors were famous for in the past). Fuel trim numbers would be skewed and you should have a CEL if it were merely dirty. You didn't put a K&N filter in there dripping with oil, did you?
If a bug was caught in it you might not be able to drive it at all. This seems to happen a lot when cheapo air filters are used on their other cars (Accord comes to mind first). This has really been the main issue with Hondas MAF sensors that I have seen consistently.
GritzNGravy
08-19-2015 03:03 AM
2005seTO
08-18-2015 12:45 PM
andyandyy
08-04-2015 06:37 PM
jessica19699
07-29-2015 05:51 AM
