LED tail/brake lights knocked out my cruise control.
Old 05-25-2015
MamaBear2015's Avatar
MamaBear2015 is an unknown quantity at this point
We have two 1998 Civics.
This is odd. Over the weekend, I replaced all the red tail and brake lights on both cars, and the center high mount brake light, with super bright LED's. ( one Cree LED at the end of each, and arrays around the body of each ).
So today, I find out that my cruise control no longer works when the lights are on, only if I turn the light off. What the....?
Old 05-25-2015
Re: LED tail/brake lights knocked out my cruise control.
I actually found the answer at
http://www.8thcivic.com/forums/mecha...e-control.html
I'm a former electronics technician and diodes are sure better than putting loads on the circuits. But does anyone know if you need a diode on each lamp that has been replaced by LED's?
Old 05-26-2015
CraigW's Avatar
Not a fan of led but, I would try loading the brake circuit with resistors. Possibly both sides.
You can slice the insulation, and tap in without cutting wires.
Old 05-26-2015
Why would I want to add wasted load to the power, when they say that series diodes will work?
Old 05-26-2015
CraigW's Avatar
Do what ever works, you have an 6th gen and the diode mod was used on an 8th.
Better keep a close eye on them, as the track record for reliability is not that great.
Old 05-26-2015
They sure are brighter, something like 2-1/2 times as bright.
Is there something in the circuitry that's THAT different with our generation, where the diodes may not work?
What's the maximum resistance that I could put across the LED's to make it work right again? I'm seeing pretty low resistance and high power being used, or some people just hanging a bulb across them, which sort of defeats the power savings.
Old 05-27-2015
CraigW's Avatar
Really no harm in trying diodes.
You could experiment with load resistors like 15 Ohms and test, you may need to go as low as 6 Ohms
Old 05-27-2015
That's a lot of heat, and may as well hang a bulb on it, if it needs all that.
Old 05-27-2015
CraigW's Avatar
Yes, it is.
The bigger load resistors come with heat sink, and mounting holes.
I have always said.... it defeats the purpose.
KronikScott
06-09-2015 08:00 PM
eorlando1
05-17-2015 11:16 AM
cukaracha
05-16-2015 02:11 PM
Supramk3
05-11-2015 07:55 PM
Quick Reply: LED tail/brake lights knocked out my cruise control.
