air conditioner compressor
Rep Power: 0 air conditioner compressor
I was driving with the ac on when I noticed it was getting colder and colder. So I shut off the ac but it stayed very cold. So I looked under the hood and noticed that even though the ac was off the clutch was still engaged. It got so cold inside even with the fan off that I had to pull #20 fuze which said ms clutch. Now does anyone know what I need to do. Pulling the fuze released the clutch. So is it a bad relay or a short in the wiring.
Thank you
PS If it is the relay where is it located. The manual only lists the fuses not the relays.
Thank you
Re: air conditioner compressor
Care to share what kind of car you have?
Clutch relay is probably stuck on. There is an updated/improved relay available.
On a Civic forum, nice.
Replace the clutch relay..
Relay position #12 in the pic here (CRV and Civic share a lot of parts)
Ask your dealer parts department for Honda part number 39794-SDA-A05.
Original failure prone relay brand is OMRON
Updated relay brand is MITSUBA
HTH
HTH
muttleytm
07-08-2015 04:13 PM
7thgensurvivor
07-05-2015 12:17 PM
