Which wire do I use? Help with car alarm please!
A long winded 7th genr
Rep Power: 263 Which wire do I use? Help with car alarm please!
I have the Matrix RSX 3.5 Car alarm, and the question is, which wires do I use for the auxiliary button? The install guide says use either H2-2 or H2-3 channels. (See attached picture.) but those are just single wires? which wire do I use to go back to the alarm brain? For example if I were to have channel 4 activate a relay, then which wire do I use to go back? I've never done this before. And to be honest, I haven't looked at the alarm brain unit yet, but the wiring guide leads me to believe that there's only one wire per channel? Can you activate a relay with just one wire? I'm lost! If anyone has any input please let me know! Thanks!
Re: Which wire do I use? Help with car alarm please!
Those are designed to drive a relay (or anything under 2/10 amp only)
They appear to be - type (sorry not sure of term used) When active they will provide a ground or - for the relay. You will provide a + voltage to one side of relay coil, and the ground for the relay coil will be provided by the alarm through these outputs.
You could test it with a meter, a test lamp or a 12 volt bulb to be sure
Rep Power: 238 Re: Which wire do I use? Help with car alarm please!
The red/white wire in the main harness on the brain is directly attached to the AUX button. It is a negative output, yes it can trigger a relay. Pressing and holding the AUX button for 1.5 seconds activates the wire.
What are you trying to hook up to this AUX button?
Rep Power: 267 Re: Which wire do I use? Help with car alarm please!
you don't go back. you give the relay a constant 12v+ signal and it sits there waiting on a ground. when the output channel is activated, it gives the relay a ground and turns it on. then you run your power for your accessory across the contacts of the relay.
Rep Power: 263 Re: Which wire do I use? Help with car alarm please!
Ah nice I understand now. Thanks so much for the help. Just to confirm what you said, when you said "Accessory" you're talking about whatever I decide to hook up to the alarm, right?
Edit: I just found a wiring diagram on autoloc's website. check it out.
now the only thing I don't understand is why there are two sets of positive wires entering the relay?
And why do I need a diode? Is there a certain kind of diode or are all diodes the same?
help from anyone would be awesome! Thanks for the teachings!
Rep Power: 304 Re: Which wire do I use? Help with car alarm please!
I agree with 130 he is dead on with this.
Not that it matters but the diagram you posted is for a set of door popers.
Yes the door poppers are what I'm trying to do.
Thanks Electric130 for your explanations I've definitely learned a couple things through this thread.
Since you're doing door poppers it might make more sense to use the violet/black Ch4 and white/black Ch5, especially if you're doing both doors. Ch4 could work the left door, Ch5 the right.
Pressing Lock and AUX on the remote would activate channel 4.
Pressing Unlock and AUX on the remote would activate channel 5.
If you want to get real crazy this could all be integrated just off the Unlock button as well.
As far as the diode, that is only in the diagram to protect the alarm brain as was stated.
Default_Slayer
Electrical DIY
12-04-2022 07:56 AM
Jon-Ohio
06-30-2018 08:10 PM
mistermenphis22
04-03-2016 08:06 AM
Linda0818
04-23-2015 11:30 AM
