rear drum to disc brake conversion DIY?
Old 10-01-2011
southern cali cruising
99dxneverstress's Avatar
99dxneverstress is an unknown quantity at this point
Question rear drum to disc brake conversion DIY?
anyone know of one? or any tips searched around through the threads didnt find anything.
99dxneverstress is offline
Old 10-03-2011
Autocross Padawan
Zeferint's Avatar
Zeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of lightZeferint is a glorious beacon of light
Re: rear drum to disc brake conversion DIY?
boilermaker made one for the 7th gens. it's very similar to the 6th gens and the thread is there for you to ask your questions and get the help and guidance you need.
link: https://www.civicforums.com/forums/4...elled-out.html
Zeferint is offline
Old 10-03-2011
much appreciated bro i'll take a look
Old 10-10-2011
redhulksmash's Avatar
redhulksmash is an unknown quantity at this point
There is a company called Scarebird that makes a bracket to do the disc conversion without swapping the control arms
then I went with rear brake components off of a 99-00 Si
need:
scarebird bracket
calipers
caliper bracket
pads
rotors
brakes hoses
e brake cables
proportioning block ( not completely needed, brakes will still favor the front though)
new spindle nuts
You could also go with brake setup off an integra or other 6th gen civic with disc brakes
redhulksmash is offline
Old 10-10-2011
CanadianCivic02's Avatar
CanadianCivic02 is an unknown quantity at this point
Do it properly and take your time, if bolts break buy oem bolts from honda not some hardware store. I see too many people locally doing this swap and having break failure while driving.
Rear disk FTW!
CanadianCivic02 is offline
Old 10-11-2011
Autocross Padawan
Zeferint's Avatar
control arms...? I think you mean trailing arms? Also, without replacing the proportioning valve, the brakes will actually favor the rear because more pressure is required to squeeze the drums than the calipers. More rear brake bias can be very dangerous, and it's best if you get a 40/40 prop valve.
Zeferint is offline
sbi
20
10-23-2015 01:34 PM
rtachs
07-16-2015 05:32 PM
Optimus34
05-25-2015 11:52 PM
rhvic
05-22-2015 03:06 PM
Broadbeb
05-14-2015 09:49 PM
Quick Reply: rear drum to disc brake conversion DIY?
